-1
I am using my Arduino uno to generate a 500Hz Square wave between 0 and 5 volts. I am measuring the signal from the Arduino using an oscilloscope and instead of measuring 5 volts peak to peak, it measures 500 millivolts. I have checked everything and cannot find anywhere a mistake. Why is this happening ?
  • \$\begingroup\$ Is your oscilloscope set to high impedance? \$\endgroup\$ – Blair Fonville May 14 at 3:23
  • \$\begingroup\$ Does “everything” include the 10:1 probe scale? \$\endgroup\$ – Sunnyskyguy EE75 May 14 at 3:24
Make sure your scope and scope probe scaling are set to the same setting. If your scope probe is set to 10x, make sure your scope is set to 10x.
  • \$\begingroup\$ Would it be a problem if I set both to 1x ? \$\endgroup\$ – Teo Protoulis May 14 at 3:55
  • \$\begingroup\$ @TeoProtoulis 10x is better. I'll let you conduct your own research as to why. \$\endgroup\$ – Matt Young May 15 at 0:03
