20
I'm designing a circuit that includes a boost converter with a few mysterious "optional" components and I'm trying to decide whether or not to include them. Does anyone know what they do? At first I thought they might be some filter but now I'm not sure. Here's the datasheet for the FitiPower FP6717 step-up converter chip.
Typical circuit
New contributor
Steve Marwin is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
    \$\begingroup\$ RC snubber. Does the datasheet really give you no hints here on values and uses? \$\endgroup\$ – winny May 14 at 13:58
    \$\begingroup\$ Thanks! I'll do some research and see if my design needs it. Nope, the datasheet is pretty bare bones. \$\endgroup\$ – Steve Marwin May 14 at 14:03
  • \$\begingroup\$ I’ve seen worse datasheets. Unless you are making a millions of these, you have plenty of options from other vendors with better application guides and support. \$\endgroup\$ – winny May 14 at 18:43
25
The pin to which that R-C circuit connects to is the LX pin and that pin is connected to the power switches (an NMOS and a PMOS) of this converter, see the block diagram, figure 3 in the datasheet.
To keep the DCDC conversion efficient, these switches switch on/off quite rapidly. That causes the voltage on the LX pin to go up and down with high speed. This steep slopes cause EMI (Electro Magnetic Interference) emissions. So the circuit will radiate RF signals.
That is normal and to be expected and does not have to be an issue depending on your application. If it is an issue a possible solution is to make these steep slopes a bit slower, that's what this RC snubber network does. It might cost some power efficiency though so that's why the circuit is optional.
Another solution could be to place this DCDC converter in a shielded cage (Faraday cage), this can be a small metal cover on the PCB. This is used in nearly all smartphones as the DCDC converters should not disturb the phone's reception.
    \$\begingroup\$ Is the only purpose of a snubber circuit to mitigate EMI? I'm reading that they also protect the switching element from voltage spikes. \$\endgroup\$ – Steve Marwin May 14 at 14:15
    \$\begingroup\$ You're right, that is indeed also true. But as you mentioned that the circuit is "optional", the switching transistors should be able to handle the spikes without the snubber network being present. In low voltage DCDC converters like the one discussed here, the voltage spikes should not be an issue. Most low voltage designs like this one do not have a snubber network, it is simply not needed. On high voltage DCDC (flyback) converters, a snubber network can be manditory as without it the switching transistor might be damaged. \$\endgroup\$ – Bimpelrekkie May 14 at 14:22
  • \$\begingroup\$ @Bimpelrekkie Not solely flyback converters, surely? \$\endgroup\$ – Hearth May 14 at 14:42
  • \$\begingroup\$ @Hearth Indeed not only flyback converters. But I have seen snubber networks being used in flyback converters so I mentioned them as an example. A snubber network can be used anywhere where it is appropriate and needed. Another example: TRIAC based dimmers. \$\endgroup\$ – Bimpelrekkie May 14 at 15:59
I have worked with large Thyristor power supplies before. Another reason for the snubber circuit to limit the rate of voltage change, is that some components are sensitive to high dV/dt. Not that this is the reason in this particular application though. As others have said, it is more for EMI and to protect against transient spikes.
New contributor
James is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
    \$\begingroup\$ Are you sure you don't mean \$ \frac {dV}{dt} \$?. The RC snubber isn't going to sort out a step change in current. Welcome to EE.SE. \$\endgroup\$ – Transistor May 14 at 17:01
  • \$\begingroup\$ Yeah. Just realised that. It is, as you said, dV/dt. Although it does remind me of the importance of minimising any stray inductance, as the rapid change in current will cause higher voltage spikes that have to be snubbed/absorbed/dissipated. \$\endgroup\$ – James May 14 at 20:25
Mainly for EMC. Test circuit at -25 Celsius and measure EMC. Compare this measurement with EMC measurement at 25 Celsius (room temperature). You will see an amazing difference.
We had case last week where we had to decrease EMC from -91 dBm to -98 dBm for UK customer. We were successful by raising ESR from caps and coils. True, circuit efficiency is down, but we passes all compliance test.
But measure this. Measuring is knowing!!!
New contributor
user8463120 is a new contributor to this site. Take care in asking for clarification, commenting, and answering. Check out our Code of Conduct.
In this particular application, the use of an RC snubber on the SW node is to prevent Electrical Over Stress (EOS) of the LX pin / SW node.
The FP6717 boost switching regulator employs a synchronous rectifier to achieve a high DC-DC conversion efficiency. A caveat of a synchronous rectifier (logic driven pass FET) is typically an even slower rectifier turn-on time as compared to a high-speed rectifier diode.
Note the following absolute maximum voltage specification for the LX pin of the FP6717 in the datasheet:
Now, note the following scope-shot of the FP6717 operating in a 5 V demo circuit:
Notice that, for a brief period the SW node (LX Pin) rises to within 200 mV of the absolute maximum voltage rating of the converter.
Since the high-side synchronous rectifier must include a finite dead-dead time in order to avoid inadvertently crowbarring the output filter capacitors with the low side NMOS switch. For a brief period the inductor is allowed to kick-back on the switch node un-clamped (or marginally clamped via the body diode of the converter) resulting in EOS of the converter IC.
The late Jim Williams authored a nice application note on a very similar topic which applies equally well here titled: Diode Turn-On Time Induced Failures in Switching Regulators
The RC snubber also aids in EMC as others have outlined, but I believe EOS to be the #1 motivation in this application.
Steve Marwin is a new contributor. Be nice, and check out our Code of Conduct.
