My laptop died recently and I’m testing the motherboard. I’m led to believe these two MOFSETs on the board may be part of the issue PQ301 and PQ302.
Using a multimeter continuity and diode mode; PQ302 beeps between S and D on continuity mode and 0 resistance on diode mode. I’m led to believe that means it’s defective. PQ301 does nothing on both modes between the pins.
I’ve been testing them in opposite pairs i.e pins 8 and 1, 7 and 2 etc. Am I testing them correctly and if so should I go ahead and replace the mosfet and see what happens?
Here’s the diagram I’ve been looking at. Just hoping for some guidance. Thanks.
Yes, you are correct, if you have the correct polarity of your multimeter leads you should at a minimum see a diode drop between Pin 8 to Pin 1 of PQ301, best case a low ohm short.
    \$\begingroup\$ Except there's a whole laptop full of parts in parallel to the FETs. Measuring this kind of stuff in circuit is just not a good idea. \$\endgroup\$
    – JRE
    Commented May 15, 2019 at 5:46
    \$\begingroup\$ @JRE Fair enough, but measuring an un-powered component in circuit will measure lower than expected, not hi-Z. \$\endgroup\$
    – sstobbe
    Commented May 15, 2019 at 5:53
  • \$\begingroup\$ What is meant by low ohm short? On PQ301 I get .972 ohm between 8, 1 and .664 ohm between 7, 2 and .262 ohm between gate and source. \$\endgroup\$ Commented May 15, 2019 at 12:15
