A circuit with dependent and independent sources
Can someone go through why Vxy= -84mV? Given the values off VB=180mv R1=22ohms R2=68ohms R3=150 ohms. Many thanks
  • \$\begingroup\$ Homework must have an attempt at a solution, or it is off topic. \$\endgroup\$ – Voltage Spike May 16 at 20:41
  • \$\begingroup\$ This is a pretty easy problem. Where are you stuck? What have you tried? What result do you get? \$\endgroup\$ – John D May 16 at 20:48
  • \$\begingroup\$ I tried to get a value for V1, and then used KCL to get I2 and then did I2*R2. Then that voltage will be equal to Vxy? \$\endgroup\$ – James May 16 at 20:54
  • \$\begingroup\$ What result did you get for I2 and for V1? Add the equations you used to your question along with the results and we'll be able to spot your mistake. \$\endgroup\$ – John D May 16 at 21:03
  • \$\begingroup\$ Vb-V1-5V1=0.... VB=6V1.... 0.18/6=V1 = 0.03V.... Then V1/R1 +5V1/R3=I2. \$\endgroup\$ – James May 16 at 21:19
