Fan cooling is common for power electronic devices like rectifiers and inverters. Brushless DC fans have been cheap and readily available for at least 2 decades. Open frame construction is common so it is inevatable that the fan sucks dust and debris into delicate high voltage electronics causing failure. How feasable would it be to bathe a power electronics module in transformer oil? The oil is good at mains frequencies like on power distribution transformers but how would it be at say 50KHz? Would this relatively inert oil attack standard electronic components like say TO247 IGBTs, metal film caps, ceramic caps, metal film resisters?
\$\begingroup\$ I seem to recall hearing about this being called "liquid immersion cooling" (though this was coupled with someone saying they did it for their Ridiculous Gaming PC™ in their bathtub so I'm not sure the terminology is going to be exactly right) \$\endgroup\$ – Hearth May 17 '19 at 23:01
3\$\begingroup\$ Immersion cooling has been around for decades, IBM used it in supercomputing ...here is one company doing it today for datacenters: submer.com/know-more#contact It all depends on how good your cooling fluid is. Oils are used in large transformers without problems but may not be kind to labels and printing on components.3M [produce a range of inert immersion fluids: 3m.com/3M/en_US/novec-us/applications/immersion-cooling ….search there for suitable products. \$\endgroup\$ – Jack Creasey May 17 '19 at 23:07
1\$\begingroup\$ If the dielectric constant is 3 imagine what problems occur when you triple the crosstalk and load stray capacitance. Some Vegetable oil is also transformer rated \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 May 17 '19 at 23:37
1\$\begingroup\$ As an alternative, if you can fit a water block to the component(s) needing cooling, the water lines can be run to outside the enclosure where the fans can cool the radiator without getting the dust into the electronics. Like custom water cooling for PCs. \$\endgroup\$ – Andrew Morton May 18 '19 at 20:40
\$\begingroup\$ OIl simply transfers heat energy to a radiator/convector/conductor that can move it out of the system. It would be feasible to use it for this purpose BUT the need is largely well enough met by the use of "heat pipes" which use the large erngy involved in latent heat of vaporisation of the heat transfer fluid, vapour phase transport and liquid phase flow and wicking to together give energy transfer rates liable to be superior to that obtained from oil without substantial pumping. \$\endgroup\$ – Russell McMahon♦ May 19 '19 at 14:12
The fluid does only provide cooling when it is flowing, transporting the heat from e.g. the power module case to e.g. a heat exchanger. So if you want to replace a heat sink plus fan with a fluid like oil (or water), you have two options:
- Natural convection, where the oil flow is simply driven by temperature gradients and gravitational field. Oil is better in "transporting" the heat than air, but viscosity (characterizing the ability to flow easily) is much higher.
- Forced convection, where the flow is driven by a pump. If you already need a fan for air-cooling, a pump is probably required because natural convection might be not enough in your application.
Applying liquids for cooling basically just transports the heat away from the lossy component. Therefore, additionally you need a heat exchanger to dissipate the heat into the environment. In the most simple case this is the converter housing wall which needs to be of large enough surface. If the surface is not large enough, you need a heat exchanger which employs a fan for air-cooling.
In transformers (and some medium-voltage power electronics) a main argument for the oil is its properties of electrical insulation.
Oil simply transfers heat energy to a radiator/convector/conductor that can move it out of the system.
It would be feasible to use it for this purpose BUT the need is largely well enough met by the use of "heat pipes" which use the large energy involved in
- the latent heat of vaporisation of the heat transfer fluid,
- vapour phase heat-energy transport and
- liquid phase flow and wicking to recycle the energy transfer compound
Water, with among the highest latent heat of vaporisation of any substance, is a good compound for this purpose, possibly with the addition of additives to deal with corrosion and other secondary factors. Reducing pressure in the 'heat pipe' when it is sealed allows any desired transfer temperature below 100 degrees Celsius to be obtained.
