Short answer
If we draw the two voltage sources, we will easily see that they are connected (through the diodes) in parallel to the common resistor. D1 is backward-biased and turns V1 off; D2 is forward-biased and turns V2 on. So the voltage across and current through the resistor are determined by V2; the output voltage V6 is -11.4 V.
In the following lines, I will use the chance that this question gives me to reveal the philosophy of this kind of diode switching circuits.
Why are device outputs bidirectional?
To control the output voltage, device's outputs need a network of two elements in series - pull up and pull down, connected between supply rails (voltage divider configuration). In simple output stages, only one element is a transistor; the other is the load or a resistor.
Only-sourcing outputs
For example, the simple 1-transistor output stage made with an NPN transistor (emitter follower or open emmiter) can only source current to a pull-down (grounded) load.
It cannot drive pull-up loads because both the transistor and load would be pull-up elements (there would be no voltage divider formed).
Only-sinking outputs
Conversely, the emitter follower made with a PNP transistor can only sink current from a pull-up (connected to Vcc) load.
It cannot drive pull-down loads because both the transistor and load would be pull-down elements (there would be no voltage divider again).
Both sourcing and sinking outputs
Figuratively speaking, the output stages above behave as "unidirectional voltage sources". But what do we do if we need to both source and sink current in order to drive all sorts of loads? We can simply combine the two 1-transistor stages above into one complementary stage (the figure below). It can both source and sink current to pull-down and from pull-up loads behaving as a bidirectional voltage source (here the RL1-RL2 voltage divider serves as a load).
Why do we sometimes need one-way outputs?
Complementary stages are perfect but in some cases a problem appears. It sounds a bit paradoxical but in electronic circuits it is sometimes necessary to connect several voltage outputs to each other (usually we connect input to output). Typical examples are computer buses, diode logic gates, backup power supplies, etc.
But imagine we only have devices with perfect complementary outputs. If we directly join them, a conflict (short connection) between them can appear. For example, in the figure above, the left voltage follower supplies roughly 15 V to the load (RL1-RL2 voltage divider) and the right follower only 5 V. This is equivalent to a 10 V voltage source shorted. How do we resolve such a conflict?
From two-way back to one-way
We know the one-way outputs do not have this problem. So we start looking for a way to turn the two-way output back into a one-way output. The funny thing here is that we assembled it with two transistors and now, since we cannot take it apart into its component parts, we are looking for another way.
And here diodes help us to do that. By connecting a diode in series with a voltage source we make it a "unidirectional voltage source". Now we can join such outputs to solve different tasks.
Applications
Only sourcing two-way output
Two only sourcing two-way outputs joined
Only sinking two-way output
Two only sinking two-way outputs joined
Diode gates
In diode logic gates, diodes prevent conflict between the input sources (having equal voltages).
In OR gates, diodes act as switches that connect the respective input source (X1) producing logic "1" to the input of the logic gate and disconnect it when it produces logic "0". It is as if these are "double-acting" sources - they supply high voltage and close the switch in series.
So if, for example, one of the input sources produces high voltage, the others producing low voltage will be switched off and no short circuit will occur. Note: I have used ideal diodes (VF = 0 V) and real voltmeter (Rv = 10 k) as a load.
In AND gates, the diodes act as switches that connect the respective input source (X1) producing logic "0" (ground) to the input of the logic gate and disconnect it when it produces logic "1". Now the "double-acting" sources supply negative voltage and close the switch in series.
So if, for example, one of the input sources produces low voltage, the others producing high voltage will be switched off and no short circuit will occur. Note: I have used ideal diodes (VF = 0 V).
Maximum voltage selector
In other cases, the input voltages have different values. The unidirectional sources (equipped with diodes in series) are connected in parallel. Only the source with the highest voltage will be connected via its diode to the common point; the other sources will be disconnected by their diodes.
For example, let's consider a simple power supply with a backup battery. Figuratively speaking, the two sources BAT and Vs are made "unidirectional" by means of diodes D1 and D2. Since Vs is selected slightly higher than VBAT, it dominates and imposes its voltage on the load.
Minimum voltage selector
If we reverse the polarity of the sources and diodes, we get a "minimum voltage selector"; such is the OP's circuit.
Generalization
This arrangement of two voltage sources (V1 and V2) connected in parallel through two devices (D1 and D2) can be seen in many other circuit solutions. Actually the two sources are connected in series (through the ground) so their voltages are summed/subtracted and the resulting voltage is applied across the network of the two devices in series. Each of the sources tries to set the voltage of the midpoint equal to its voltage. Let's see some typical applications of this arrangement.
Diode limiters
Inverting configuration
The role of the resistor
In order to operate in the vertical part of their IV curve, diodes need a minimum current. It can be provided by the load resistance. But when the load resistance is very high or open circuit we have to connect an additional resistor in parallel with the "load". We choose its resistance in order to ensure the minimum necessary current through the diode.
