I did an experiment where I varied the test voltage and determine the values of the resistance and magnetising reactance of the core. What I noticed is that their values actually vary (not constant). Ideally speaking, shouldn't their values be constant regardless of the test voltage (while they vary in practice)?
The magnetizing reactance decreases as the iron becomes saturated with increased voltage. The resistance increases as the current increase causes the winding temperature to increase.
The point is: we calculate the paremeters of equivalent circuit as ideally and in a specific contour conditions. But the core is made with non-linear material, and the losses have exponential bahavior in some regions of operation. Because it, these parameters are not constants with all applied conditions.
As follow, an example of a characterisc permeabillity curve for a silicon iron: enter image description here
https://www.researchgate.net/publication/283131025_Some_important_effects_of_the_water_jet_and_laser_cutting_methods_on_the_magnetic_properties_of_the_non-oriented_silicon_iron_sheets
V=LdI/dt + IRs such that when dI/dt reduces it is due to drop in L due to saturation and rise in Rs if self-heating. This may be tested with DC-CV, CC or Vac (CV or CC) to measure L depending on the size of the core and it’s current rating.
