This question already has an answer here:
hi i have implemented this equation with XOR and Not gate but i'm not getting the correct answers (A.B.C)+(A'.B'.C')
What is the Problem ? thank you
marked as duplicate by Community May 18 at 6:50
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • \$\begingroup\$ There are IC's that have three input XNOR gates, i.e. the 74HC27. What's the purpose of this project? \$\endgroup\$ – KingDuken May 18 at 6:07
  • \$\begingroup\$ we have to design it only with XOR and NOT gate IC's and looks like Y=(A.B.C)+(A'.B'.C') is not 3 input XNOR :( \$\endgroup\$ – pooya May 18 at 6:17
What you should get is an XNOR gate (Y=A'B'C'+ABC'+A'BC+AB'C) "an even number of ones". As an XOR gate will give an output that is true if and only if an "odd number of ones" is deriving it. So, inverting the XOR gate will results in an XNOR gate that will give an output which is true if and only if an "even number of ones" is deriving it.
