My transmitter consists of this exact IR LED, with an 180 ohm resistor, operating at 5V, that is being pulsed by an ATTINY13 using this code:
void setup(){
  DDRB |= (1<<PB0); //Set pin PB0 as output
  DDRB |= (1<<PB1); //Set pin PB1 as output
  TCNT0 = 0;
  TCCR0A=0;
  TCCR0B=0;
  TCCR0A |=(1<<COM0A0); //Timer0 in toggle mode Table 11-2
  TCCR0A |=(1<<WGM01); //Start timer 1 in CTC mode Table 11.5
  TCCR0B |= (1 << CS00);// Prescaler table 11.6
  OCR0A=110; //CTC Compare value, 36khz
void loop(){
  TCCR0A &= ~(1<<COM0A0); //off
  delay(500);
  TCCR0A |=(1<<COM0A0); //on
  delay(500);
Arduino ISP was used to program the chip.
The receiver is a TSOP1236 (datasheet in PDF).
A timer, on the receiver's end, is running and resets every time a burst is detected. If it misses, meaning it wasn't detected after x ms, it fires an alarm, indicating that somebody disrupted the beam and thus walked past.
Perhaps using a correct burst/gap rate and ratio, suited to the TSOP, could help me code the timer in C by making the gap more consistent?
What would be a good burst/gap rate and ratio? Which value would you suggest for the delay in the loop() function? I am too much of a rookie to find any indications in the TSOP datasheet to help.
