I want to display a sine wave on oscilloscope using AVR Atmega164, but when I put the oscilloscope on the pin OCR0A, it takes me an rectangular pulse. How can I display a sine wave? I will put my code below:
const uint8_t PROGMEM sinewave[] = {
    0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8a,0x8b,0x8c,0x8d,0x8e,
    0x8f,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x9a,0x9b,0x9c,0x9d,0x9e,
    0x9f,0xa0,0xa1,0xa2,0xa3,0xa4,0xa5,0xa6,0xa7,0xa8,0xa9,0xaa,0xab,0xac,0xad,
    0xae,0xaf,0xb0,0xb1,0xb2,0xb3,0xb4,0xb5,0xb6,0xb7,0xb8,0xb9,0xba,0xbb,0xbc,
    0xbd,0xbe,0xbf,0xc0,0xc1,0xc2,0xc2,0xc3,0xc4,0xc5,0xc6,0xc7,0xc8,0xc9,0xca,
    0xca,0xcb,0xcc,0xcd,0xce,0xcf,0xd0,0xd0,0xd1,0xd2,0xd3,0xd4,0xd4,0xd5,0xd6,
    0xd7,0xd8,0xd8,0xd9,0xda,0xdb,0xdb,0xdc,0xdd,0xde,0xde,0xdf,0xe0,0xe0,0xe1,
    0xe2,0xe2,0xe3,0xe4,0xe4,0xe5,0xe6,0xe6,0xe7,0xe8,0xe8,0xe9,0xe9,0xea,0xeb,
    0xeb,0xec,0xec,0xed,0xed,0xee,0xee,0xef,0xef,0xf0,0xf0,0xf1,0xf1,0xf2,0xf2,
    0xf3,0xf3,0xf4,0xf4,0xf5,0xf5,0xf5,0xf6,0xf6,0xf7,0xf7,0xf7,0xf8,0xf8,0xf8,
    0xf9,0xf9,0xf9,0xfa,0xfa,0xfa,0xfb,0xfb,0xfb,0xfb,0xfc,0xfc,0xfc,0xfc,0xfd,
    0xfd,0xfd,0xfd,0xfd,0xfd,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xff,0xff,0xff,
    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
    0xff,0xff,0xff,0xff,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xfe,0xfd,0xfd,0xfd,0xfd,
    0xfd,0xfd,0xfc,0xfc,0xfc,0xfc,0xfb,0xfb,0xfb,0xfb,0xfa,0xfa,0xfa,0xf9,0xf9,
    0xf9,0xf8,0xf8,0xf8,0xf7,0xf7,0xf7,0xf6,0xf6,0xf5,0xf5,0xf5,0xf4,0xf4,0xf3,
    0xf3,0xf2,0xf2,0xf1,0xf1,0xf0,0xf0,0xef,0xef,0xee,0xee,0xed,0xed,0xec,0xec,
    0xeb,0xeb,0xea,0xe9,0xe9,0xe8,0xe8,0xe7,0xe6,0xe6,0xe5,0xe4,0xe4,0xe3,0xe2,
    0xe2,0xe1,0xe0,0xe0,0xdf,0xde,0xde,0xdd,0xdc,0xdb,0xdb,0xda,0xd9,0xd8,0xd8,
    0xd7,0xd6,0xd5,0xd4,0xd4,0xd3,0xd2,0xd1,0xd0,0xd0,0xcf,0xce,0xcd,0xcc,0xcb,
    0xca,0xca,0xc9,0xc8,0xc7,0xc6,0xc5,0xc4,0xc3,0xc2,0xc2,0xc1,0xc0,0xbf,0xbe,
    0xbd,0xbc,0xbb,0xba,0xb9,0xb8,0xb7,0xb6,0xb5,0xb4,0xb3,0xb2,0xb1,0xb0,0xaf,
    0xae,0xad,0xac,0xab,0xaa,0xa9,0xa8,0xa7,0xa6,0xa5,0xa4,0xa3,0xa2,0xa1,0xa0,
    0x9f,0x9e,0x9d,0x9c,0x9b,0x9a,0x99,0x98,0x97,0x96,0x95,0x94,0x93,0x92,0x91,
    0x8f,0x8e,0x8d,0x8c,0x8b,0x8a,0x89,0x88,0x87,0x86,0x85,0x84,0x83,0x82,0x81,
    0x80,0x7e,0x7d,0x7c,0x7b,0x7a,0x79,0x78,0x77,0x76,0x75,0x74,0x73,0x72,0x71,
    0x70,0x6e,0x6d,0x6c,0x6b,0x6a,0x69,0x68,0x67,0x66,0x65,0x64,0x63,0x62,0x61,
    0x60,0x5f,0x5e,0x5d,0x5c,0x5b,0x5a,0x59,0x58,0x57,0x56,0x55,0x54,0x53,0x52,
    0x51,0x50,0x4f,0x4e,0x4d,0x4c,0x4b,0x4a,0x49,0x48,0x47,0x46,0x45,0x44,0x43,
    0x42,0x41,0x40,0x3f,0x3e,0x3d,0x3d,0x3c,0x3b,0x3a,0x39,0x38,0x37,0x36,0x35,
    0x35,0x34,0x33,0x32,0x31,0x30,0x2f,0x2f,0x2e,0x2d,0x2c,0x2b,0x2b,0x2a,0x29,
    0x28,0x27,0x27,0x26,0x25,0x24,0x24,0x23,0x22,0x21,0x21,0x20,0x1f,0x1f,0x1e,
    0x1d,0x1d,0x1c,0x1b,0x1b,0x1a,0x19,0x19,0x18,0x17,0x17,0x16,0x16,0x15,0x14,
    0x14,0x13,0x13,0x12,0x12,0x11,0x11,0x10,0x10,0xf,0xf,0xe,0xe,0xd,0xd,
    0xc,0xc,0xb,0xb,0xa,0xa,0xa,0x9,0x9,0x8,0x8,0x8,0x7,0x7,0x7,
    0x6,0x6,0x6,0x5,0x5,0x5,0x4,0x4,0x4,0x4,0x3,0x3,0x3,0x3,0x2,
    0x2,0x2,0x2,0x2,0x2,0x1,0x1,0x1,0x1,0x1,0x1,0x1,0x0,0x0,0x0,
    0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,
    0x0,0x0,0x0,0x0,0x1,0x1,0x1,0x1,0x1,0x1,0x1,0x2,0x2,0x2,0x2,
    0x2,0x2,0x3,0x3,0x3,0x3,0x4,0x4,0x4,0x4,0x5,0x5,0x5,0x6,0x6,
    0x6,0x7,0x7,0x7,0x8,0x8,0x8,0x9,0x9,0xa,0xa,0xa,0xb,0xb,0xc,
    0xc,0xd,0xd,0xe,0xe,0xf,0xf,0x10,0x10,0x11,0x11,0x12,0x12,0x13,0x13,
    0x14,0x14,0x15,0x16,0x16,0x17,0x17,0x18,0x19,0x19,0x1a,0x1b,0x1b,0x1c,0x1d,
    0x1d,0x1e,0x1f,0x1f,0x20,0x21,0x21,0x22,0x23,0x24,0x24,0x25,0x26,0x27,0x27,
    0x28,0x29,0x2a,0x2b,0x2b,0x2c,0x2d,0x2e,0x2f,0x2f,0x30,0x31,0x32,0x33,0x34,
    0x35,0x35,0x36,0x37,0x38,0x39,0x3a,0x3b,0x3c,0x3d,0x3d,0x3e,0x3f,0x40,0x41,
    0x42,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x4a,0x4b,0x4c,0x4d,0x4e,0x4f,0x50,
    0x51,0x52,0x53,0x54,0x55,0x56,0x57,0x58,0x59,0x5a,0x5b,0x5c,0x5d,0x5e,0x5f,
    0x60,0x61,0x62,0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x6a,0x6b,0x6c,0x6d,0x6e,
    0x70,0x71,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7a,0x7b,0x7c,0x7d,0x7e };
uint8_t i=0;
ISR(TIM0_OVF) {
   OCR0A = pgm_read_byte(&sinewave[i]);
   // update duty cycle
   i++;
void main() {
     DDRB = 0xFF;
     TCCR0A = 0x83;
     TCCR0B = (1 << WGM12);
     TIMSK0 |= (1 << TOIE0);
     TIFR0 |= (1 << OCF0A);
     TCCR0B = (1 << CS10);
     TCNT0 = 0;
     OCR0A = 0x80;
     sei();
     while(1) { }
  • 7
    \$\begingroup\$ OCR0A is a register and not a pin. Maybe you mean the OC0A pin and this is a digital pin used to output PWM - are you believing you can extract an analogue voltage from this pin without using an external analogue low pass filter? \$\endgroup\$ – Andy aka May 22 at 12:51
  • \$\begingroup\$ On top of that, your 'i' variable is 8 bits, so it will max out at 255 before it overflows to 0, but you are using it to index an array with around 750 data points .... I'm guessing you think the values in this array will generate a sine wave by turning OC0A on/off for a controlled amount of time? Like Andy said, you have to filter this digital signal externally to convert it to analog. \$\endgroup\$ – Kurt E. Clothier May 23 at 21:58
