Is there a way, other then remembering, to figure out what resistors are in both of these series?
\$\begingroup\$ Somewhat related and possibly useful and note that if consecutive resistors were proportioned identically you would have nearly as many subtle ratio choices when making a potential divider. \$\endgroup\$– Andy akaMay 23, 2019 at 12:35
1\$\begingroup\$ How do you mean? Are you asking if there is a formula? Have you read: en.wikipedia.org/wiki/E_series_of_preferred_numbers Since the series are "roughly equally spaced values on a logarithmic scale" there is no "hard" relation, some rounding off was done. So the values are mostly chosen and there is no other way to know the range than to memorize it. E12 is easy, I know it from heart: 1.0, 1.2, 1.5, 1.8, 2,2. 2.7, 3.3, 3.9, 4.7, 5.6, 6.8, 9.1. Then all resistors are 1, 10, 100, 1k, 10k, 100k, 1M 10M times that value up to 10 M ohm. \$\endgroup\$– BimpelrekkieMay 23, 2019 at 12:36
1\$\begingroup\$ As @Bimpelrekkie says - they are at nominally constant ratio. Rn = Rn-1 x 12th root of 10 You then round that to 2 digits BUT at east one round wrong :-). | For E24 Rn = Rn-1 x 24th root of 10. || Obvious point of great use that is seldom mentioned. - The ratio of any two values N steps away is the same (subject to rounding errors). so eg 1.8/1.2 ~= 3.9/2.7 ~= 6.8/4.7 etc \$\endgroup\$– Russell McMahon ♦May 23, 2019 at 13:43
\$\begingroup\$ @bimpq 6.8 - 8.2 - 10. You knew that :-) \$\endgroup\$– Russell McMahon ♦May 23, 2019 at 13:43
\$\begingroup\$ The explanation is here. \$\endgroup\$– jonkMay 23, 2019 at 13:59
To answer your question about the E12 and E24 series, you have to go back to the E3 series. There's no escaping that fact. You cannot derive the values for E12 or E24, without retracing backward to E3.
Historical Context
The history of this goes back at least to Charles Renard, who proposed specific ways of arranging numbers to divide (decimal) intervals. He focused on dividing decades in 5, 10, 20, and 40 steps, where the logarithm of each step value would form an arithmetic series. His choices became known as R5, R10, R20, and R40.
Renard numbering was extended to include other special versions, such as R10/3, R20/3, and R40/3. Here, these were interpreted to mean that you would use the R10, R20, and R40 decade series approaches but would step across values, taking them three at a time, for example. So R20/3 means to use R20, but to select only every 3rd term as in: \$10\cdot 10^\frac{0}{20}\approx 10\$, \$10\cdot 10^\frac{3}{20}\approx 14\$, \$10\cdot 10^\frac{6}{20}\approx 20\$, \$10\cdot 10^\frac{9}{20}\approx 28\$, \$10\cdot 10^\frac{12}{20}\approx 40\$, \$10\cdot 10^\frac{15}{20}\approx 56\$, and \$10\cdot 10^\frac{18}{20}\approx 79\$.
If you want to read further, the above and a lot more can be found in a publication called NBS Technical Note 990 (1978). (The National Bureau of Standards [NBS] is now NIST.)
After WW II there was a strong push towards standardizing manufactured parts. So various groups "rationalized" standard values to aid manufacturing, instrumentation, and so on. For example, the numbers of teeth on gears and the values of resistors.
E-Series (Geometric)
You need to start with the E3 series to work out the values. The reason is that the idea of coverage is most crucial for E3 and least crucial for E24. So you have to start at E3 in order to find out why certain values are selected for E12 and E24.
I'll start with the full diagram and then explain the details of each step along the way in a moment:
Starting with E3, simple computation yields: \$\begin{align*}\textbf{E3}&\left\{\begin{array}{l}\lfloor 10^{1+\frac{0}{3}}+0.5\rfloor= 10\\\lfloor 10^{1+\frac{1}{3}}+0.5\rfloor= 22\\\lfloor 10^{1+\frac{2}{3}}+0.5\rfloor= 46\end{array}\right.\end{align*}\$
But there's an immediate problem related to coverage. They are all even and there's no way of composing odd numbers using only even numbers.
At least one of these numbers must change, but they cannot change 10 for obvious reasons. To change just one, the only possibilities are: \$\begin{align*}\textbf{E3}_1&\left\{\begin{array}{l}10\\\textbf{23}\\46\end{array}\right.\end{align*}\$, or else, \$\begin{align*}\textbf{E3}_2&\left\{\begin{array}{l}10\\22\\\textbf{47}\end{array}\right.\end{align*}\$. But \$\textbf{E3}_1\$ still has a problem related to coverage. The difference between 46 and 23 is itself just 23. And this combined value is a number already in the sequence. In contrast, \$\textbf{E3}_2\$ doesn't have that problem, as the differences and sums provide useful values not already in the sequence.
Rationalized, \$\begin{align*}\textbf{E3}&\left\{\begin{array}{l}10\\22\\\textbf{47}\end{array}\right.\end{align*}\$
The next step is to examine E6. First and foremost, E6 must preserve the values that were determined for E3. That's a given that cannot be avoided. Accepting that requirement, the computed values for E6 are \$\begin{align*}\textbf{E6}&\left\{\begin{array}{l}10\\\lfloor 10^{1+\frac{1}{6}}+0.5\rfloor= 15\\22\\\lfloor 10^{1+\frac{3}{6}}+0.5\rfloor= 32\\\textbf{47}\\\lfloor 10^{1+\frac{5}{6}}+0.5\rfloor= 68\end{array}\right.\end{align*}\$
But a coverage problem shows up, again. The difference between 32 and 22 is 10 and this is one of the values already in the sequence. Also, 47 minus 32 is 15. So there are at least two problems to solve. And 32 is involved in both. Changing it to 33 solves these problems and provides the needed coverage.
Rationalized, \$\begin{align*}\textbf{E6}&\left\{\begin{array}{l}10\\15\\22\\\textbf{33}\\\textbf{47}\\68\end{array}\right.\end{align*}\$
E12 must preserve the values that were determined for E6, of course. The computed values for E12 are: \$\begin{align*}\textbf{E12}&\left\{\begin{array}{l}10\\\lfloor 10^{1+\frac{1}{12}}+0.5\rfloor= 12\\15\\\lfloor 10^{1+\frac{3}{12}}+0.5\rfloor= 18\\22\\\lfloor 10^{1+\frac{5}{12}}+0.5\rfloor= 26\\\textbf{33}\\\lfloor 10^{1+\frac{7}{12}}+0.5\rfloor= 38\\\textbf{47}\\\lfloor 10^{1+\frac{9}{12}}+0.5\rfloor= 56\\68\\\lfloor 10^{1+\frac{11}{12}}+0.5\rfloor= 83\end{array}\right.\end{align*}\$
More coverage problems, of course. 83 minus 68 is 15 and 15 is already in the sequence. Adjusting that to 82 solves this issue. But 26 has a prior span of 4 and a following span of 7; and 38 has a prior span of 5 and a following span of 9. These spans should, roughly speaking, be monotonically increasing. This situation is quite serious and the only options really are to adjust 26 to the next nearest upward alternative of 27 and to adjust 38 to its nearest upward alternative of 39.
Rationalized, \$\begin{align*}\textbf{E12}&\left\{\begin{array}{l}10\\12\\15\\18\\22\\\textbf{27}\\\textbf{33}\\\textbf{39}\\\textbf{47}\\56\\68\\\textbf{82}\end{array}\right.\end{align*}\$
Feel free now to work out for yourself E24. You'll reach the obvious conclusions, I think. And you'll agree that the above table at the outset has been properly rationalized.
Notes
- The sum or difference of preferred numbers tend to avoid being a preferred number, where possible. This is required in order to provide as much coverage as possible.
- The product, or quotient, or any integral positive or negative power of preferred numbers will be a preferred number.
- Squaring a preferred number in the E12 series produces a value in the E6 series. Similarly, squaring a preferred number in the E24 series produces a value in the E12 series. Etc.
- Taking the square root of a preferred number in the E12 series produces an intermediate value in the E24 series that isn't present in the E12 series. Similarly, taking the square root of a preferred number in the E6 series produces an intermediate value in the E12 series that isn't present in the E6 series. Etc.
(The above is exactly true when using the theoretical values rather than the preferred values. But since the preferred values have been adjusted by the rationalizing process, there will be some deviation.)
Footnote: This post is related to another I've added here.
4\$\begingroup\$ Terrific explanation of the history and tradeoffs! \$\endgroup\$ May 23, 2019 at 23:05
\$\begingroup\$ Is there actual historical evidence for this derivation path or is it just a theory that happens to fit the facts? \$\endgroup\$ Sep 11, 2020 at 23:12
1\$\begingroup\$ @PeterGreen I've provided a key reference that I studied. It was the best I could find, without having to pay for it. I did review other work products, as well. An historian might be able to provide the necessary research and work needed to provide a full historical record. But if you don't care about the history and are willing to pay, then ISO 497:1973, Guide to the choice of series of preferred numbers and of series containing more rounded values of preferred numbers and ISO 17:1973, Guide to the use of preferred numbers and of series of preferred numbers would be the places. \$\endgroup\$– jonkSep 12, 2020 at 1:18
\$\begingroup\$ @PeterGreen That said, I believe the inferences I made are solid and I'd be willing to defend them. Both by the information gathered as source material and background as well as the logic I applied (and disclosed here.) I believe my reasoning is quite sound. If you find anything wrong with the process, let me know. If you find anything better, let me know. But as it is, I think I've re-traversed the actual process that was earlier applied. Having read through that entire document, considered its contents in full, and from the rest of what I also read, I'm about as certain as I may be. \$\endgroup\$– jonkSep 12, 2020 at 1:22
Really short:
Within one decade the sequence of the E\$n\$ series, you get the values
$$V_{\text E n}= \left\{10^{\frac mn} {\Big|} m \in \{0,\ldots, n-1\} \right\}$$
However, this will give you values that then get rounded to two digits after the decimal point – and not necessarily correctly so.
In other words, it turns out that no, there's no mathematical formula that gives you the actual series. Just one that gives you what the series should have been, but isn't.
1\$\begingroup\$ But that is not actually accurate, there are some values that are slightly off, for some reason. This kind of charts seem to be the only reliable way logwell.com/tech/components/resistor_values.html \$\endgroup\$– TemeVMay 23, 2019 at 12:48
\$\begingroup\$ Note that on there's also some rounding off to "nice" values done after this formula: for example V(n=1) = 1.2115 which becomes 1.2 and V(n=8) = 4.6416 which becomes 4.7 (note how that's not properly rounded off, it should have been 4.6). \$\endgroup\$ May 23, 2019 at 12:51
\$\begingroup\$ @TemeV slightly off, for some reason That's explained in the wikipedia page: en.wikipedia.org/wiki/E_series_of_preferred_numbers to make the numbers "nicer", it is rounding off + making the range "look nice". \$\endgroup\$ May 23, 2019 at 12:52
\$\begingroup\$ I was referring to those incorrectly rounded values. If you're e.g. trying to generate the series in Excel, the equation gives some wrong values. (Been there done that...) \$\endgroup\$– TemeVMay 23, 2019 at 12:58
See Wikipedia: E_series_of_preferred_numbers.
Especially this fragment:
E12 values (10% tolerance)
1.0, 1.2, 1.5, 1.8, 2.2, 2.7, 3.3, 3.9, 4.7, 5.6, 6.8, 8.2
E24 values (5% tolerance)
1.0, 1.1, 1.2, 1.3, 1.5, 1.6, 1.8, 2.0, 2.2, 2.4, 2.7,
3.0, 3.3, 3.6, 3.9, 4.3, 4.7, 5.1, 5.6, 6.2, 6.8, 7.5, 8.2, 9.1
As you can see E12 is a subset of E24.
\$\begingroup\$ Note that this is not necessarily true for the later series. E24 is not a subset of E48 due to rounding differences in the higher precision of E48; for example, there is a 1.5 in E24 but no 1.50 in E48; instead, you have to pick between 1.47 and 1.54. \$\endgroup\$– HearthMay 23, 2019 at 17:15
