i want to charge two 25F Supercaps (in series) in two stages: while their total voltage is under 5v, i want to charge them slowly via a resistor R3 of around 100 Ohm. After they reach the desired Voltage (2.5v each) i want to bypass R3 with 1 Ohm, effectively shorting out R3. I thought i could use a Logic Level Mosfet (irlz34n) for that, creating the gate voltage (around 2.5V) with a Voltage divider (R1 and R2). However, this seems impossible. While the Vcc of 5v is present, the gate voltage is higher then the expected voltage for each Supercap (caused by the voltage dropped over R3). Only if i disconnect vcc, the circuit works as i intend... Is there any way to short out R3, when the caps have reached 5v? Thank you for your help.enter image description here
  • \$\begingroup\$ Your circuit is "strange". Your gate voltage = V_C2 + V_C1/2 ~= 3.75V when the capacitors are charged. r! + r2 ACT AS A DRAIN ON c1 WHEN CHARGED. | One solution is to sense the voltage at C2-R3 junction and use it to operate Q1 when this voltage FALLS to almost zero (as current in R3 falls to almost zero |Saying what you are trying to achieve and NOT how you think it can be done is liable to get you better quicker answers. eg if you intend the 5v point to be a bidirectional charge-in/battery backupout point? If so, what is meant to happen when Vcaps falls substantially? ... \$\endgroup\$ – Russell McMahon May 25 '19 at 11:54
  • \$\begingroup\$ ... As shown R3 will switch back in again - you need hysteresis if you want Vcap to fall very far without R3 switching back in. Tell us what you want and we'll give you what you need :-). \$\endgroup\$ – Russell McMahon May 25 '19 at 11:54
R1 + R2 act as an ongoing load on C1 when charged. .
Saying what you are trying to achieve and NOT how you think it can be done is liable to get you better quicker answers. eg if you intend the 5v point to be a bidirectional charge-in/battery backup-out point?
If so, what is meant to happen when Vcaps falls substantially? As shown, R3 will switch back in again - you need hysteresis if you want Vcap to fall very far without R3 switching back in.
This circuit shows the principle.
It would be better to use an opamp or comparator as you can then control the shorting-FET starting voltage and hysteresis voltage far more easily.
5V power on. C3 holds gate low briefly (important).
Without C3 the FET turns on at power up, clamps Q1 base low and the circuit fails to provide the desired slow charge.
Caps charge via R1.
V_R1 > 0.6V turns on Q1.
Q1 on holds FET off.
When V_R1 falls to under ABOUT 0.6V Q1 turns off.
Q1 turning off allows R3 to turn FET on.
FET on shorts caps AND (important) clamps V_R1 low so Q1 cannot turn on again as cap voltage falls.
Circuit does not "reset" unti Vcaps is very low. If you want some intermediate voltage reset point (so caps can be recharged) it could be done with this circuit but using an opamp will make it far easier and better defined.
Here V_R1 must be > 0.6V to keep R1 in circuit. With an opamp this voltage can be set by design.
| improve this answer | |
  • \$\begingroup\$ Great!, Thanks for the advice (also on posting questions). Yes, slow charging and then serving as a backup power supply is exactly what i want. The circuit is intended to power a raspberry pi for a brief time to enable it to shutdown savely after a powerloss. It would be ideal to have a "reset point" at about 4.2 or so volts (meaning only slow charging when voltage falls under 4.2V, as i think my psu can handle charging the caps from 4.2V to 5V directly). I am not very familiar with transistors and opamps. I would be grateful for another advice on how to set the "reset point" - voltage. \$\endgroup\$ – matchless_clueless May 25 '19 at 13:09
  • \$\begingroup\$ PS: I knew R1 and R2 would be a constant load to C1, but i imagined their values to be very high, so it wouldn't matter. Anyway, that was clearly the wrong approach. \$\endgroup\$ – matchless_clueless May 25 '19 at 13:09
