I bought STM32 F401RE and Ethernet shield HR911105A with MCU W5100. I'm not able to configure simple connectivity with it. I have setup all SPI wires and simple code for setting up IP, subnet, and default gateway. I was following this tutorial but the solution doesn't work for me. I have triple checked the wiring and the setup config but I cannot find why I'm not able to just setup IP.
Tutorial link: https://www.carminenoviello.com/2015/08/28/adding-ethernet-connectivity-stm32-nucleo/
All those things are auto-generated by STM32cubeMX except a few lines of code in main.c in user sections.
Ethernet shield library: ioLibrary_Driver
I'm able to compile and run it but I'm not able to assign IP. I tried also mbed online compiler with simple example and then used with ST-LINK Utility to program MCU and the program works fine. The IP is assigned. So there is not problem with Ethernet shield.
This is what I get:
Network configuration:
  MAC ADDRESS: ff:ff:ff:ff:ff:ff
  IP ADDRESS:  255.255.255.255
  NETMASK:     255.255.255.255
  GATEWAY:     255.255.255.255
Here is the code that I'm using main.c:
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * <h2><center>&copy; Copyright (c) 2019 STMicroelectronics.
  * All rights reserved.</center></h2>
  * This software component is licensed by ST under BSD 3-Clause license,
  * the "License"; You may not use this file except in compliance with the
  * License. You may obtain a copy of the License at:
  *                        opensource.org/licenses/BSD-3-Clause
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "dns.h"
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
#define SEPARATOR            "=============================================\r\n"
#define WELCOME_MSG          "Welcome to STM32Nucleo Ethernet configuration\r\n"
#define NETWORK_MSG          "Network configuration:\r\n"
#define IP_MSG               "  IP ADDRESS:  %d.%d.%d.%d\r\n"
#define NETMASK_MSG          "  NETMASK:     %d.%d.%d.%d\r\n"
#define GW_MSG               "  GATEWAY:     %d.%d.%d.%d\r\n"
#define MAC_MSG              "  MAC ADDRESS: %x:%x:%x:%x:%x:%x\r\n"
#define GREETING_MSG         "Well done guys! Welcome to the IoT world. Bye!\r\n"
#define CONN_ESTABLISHED_MSG "Connection established with remote IP: %d.%d.%d.%d:%d\r\n"
#define SENT_MESSAGE_MSG     "Sent a message. Let's close the socket!\r\n"
#define WRONG_RETVAL_MSG     "Something went wrong; return value: %d\r\n"
#define WRONG_STATUS_MSG     "Something went wrong; STATUS: %d\r\n"
#define LISTEN_ERR_MSG       "LISTEN Error!\r\n"
#define PRINT_STR(msg) do  {                                        \
  HAL_UART_Transmit(&huart2, (uint8_t*)msg, strlen(msg), 100);      \
} while(0)
#define PRINT_HEADER() do  {                                                    \
  HAL_UART_Transmit(&huart2, (uint8_t*)SEPARATOR, strlen(SEPARATOR), 100);      \
  HAL_UART_Transmit(&huart2, (uint8_t*)WELCOME_MSG, strlen(WELCOME_MSG), 100);  \
} while(0)
#define PRINT_NETINFO(netInfo) do {        \
  HAL_UART_Transmit(&huart2, (uint8_t*)NETWORK_MSG, strlen(NETWORK_MSG), 100);                                          \
  sprintf(msg, MAC_MSG, netInfo.mac[0], netInfo.mac[1], netInfo.mac[2], netInfo.mac[3], netInfo.mac[4], netInfo.mac[5]);\
  sprintf(msg, IP_MSG, netInfo.ip[0], netInfo.ip[1], netInfo.ip[2], netInfo.ip[3]);                                     \
  sprintf(msg, NETMASK_MSG, netInfo.sn[0], netInfo.sn[1], netInfo.sn[2], netInfo.sn[3]);                                \
  sprintf(msg, GW_MSG, netInfo.gw[0], netInfo.gw[1], netInfo.gw[2], netInfo.gw[3]);                                     \
} while(0)
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
SPI_HandleTypeDef hspi2;
UART_HandleTypeDef huart2;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART2_UART_Init(void);
static void MX_SPI2_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
void cs_sel() {
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_12, GPIO_PIN_RESET); //CS LOW
void cs_desel() {
    HAL_GPIO_WritePin(GPIOB, GPIO_PIN_12, GPIO_PIN_SET); //CS HIGH
uint8_t spi_rb(void) {
    uint8_t rbuf;
    HAL_SPI_Receive(&hspi2, &rbuf, 1, 0xFFFFFFFF);
    return rbuf;
void spi_wb(uint8_t b) {
    HAL_SPI_Transmit(&hspi2, &b, 1, 0xFFFFFFFF);
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  char msg[60];
    uint8_t retVal, sockStatus;
    int16_t rcvLen;
    uint8_t rcvBuf[20], bufSize[] = {2, 2, 2, 2};
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_USART2_UART_Init();
  MX_SPI2_Init();
  /* USER CODE BEGIN 2 */
  PRINT_HEADER();
  reg_wizchip_cs_cbfunc(cs_sel, cs_desel);
  reg_wizchip_spi_cbfunc(spi_rb, spi_wb);
//      wiz_NetInfo netInfo = { 0 };
  wizchip_init(bufSize, bufSize);
   wiz_NetInfo netInfo = { .mac     = {0x00, 0x08, 0xdc, 0xab, 0xcd, 0xef}, // Mac address
                             .ip    = {192, 168, 2, 100},                   // IP address
                             .sn    = {255, 255, 255, 0},                   // Subnet mask
                             .gw    = {192, 168, 2, 1}
//                           .dns   = {8, 8, 8, 8},
//                           .dhcp  = NETINFO_STATIC
                       };                   // Gateway address
     wizchip_setnetinfo(&netInfo);
     wizchip_getnetinfo(&netInfo);
     PRINT_NETINFO(netInfo);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE2);
  /** Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  RCC_OscInitStruct.PLL.PLLM = 16;
  RCC_OscInitStruct.PLL.PLLN = 336;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
  RCC_OscInitStruct.PLL.PLLQ = 7;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
  * @brief SPI2 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN SPI2_Init 0 */
  /* USER CODE END SPI2_Init 0 */
  /* USER CODE BEGIN SPI2_Init 1 */
  /* USER CODE END SPI2_Init 1 */
  /* SPI2 parameter configuration*/
  hspi2.Instance = SPI2;
  hspi2.Init.Mode = SPI_MODE_MASTER;
  hspi2.Init.Direction = SPI_DIRECTION_2LINES;
  hspi2.Init.DataSize = SPI_DATASIZE_8BIT;
  hspi2.Init.CLKPolarity = SPI_POLARITY_LOW;
  hspi2.Init.CLKPhase = SPI_PHASE_1EDGE;
  hspi2.Init.NSS = SPI_NSS_SOFT;
  hspi2.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_4;
  hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB;
  hspi2.Init.TIMode = SPI_TIMODE_DISABLE;
  hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
  hspi2.Init.CRCPolynomial = 10;
  if (HAL_SPI_Init(&hspi2) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN SPI2_Init 2 */
  /* USER CODE END SPI2_Init 2 */
  * @brief USART2 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN USART2_Init 0 */
  /* USER CODE END USART2_Init 0 */
  /* USER CODE BEGIN USART2_Init 1 */
  /* USER CODE END USART2_Init 1 */
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 115200;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  huart2.Init.StopBits = UART_STOPBITS_1;
  huart2.Init.Parity = UART_PARITY_NONE;
  huart2.Init.Mode = UART_MODE_TX_RX;
  huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart2) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN USART2_Init 2 */
  /* USER CODE END USART2_Init 2 */
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  __HAL_RCC_GPIOB_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(LD2_GPIO_Port, LD2_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pin : B1_Pin */
  GPIO_InitStruct.Pin = B1_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  HAL_GPIO_Init(B1_GPIO_Port, &GPIO_InitStruct);
  /*Configure GPIO pin : LD2_Pin */
  GPIO_InitStruct.Pin = LD2_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(LD2_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
Here is additional setup in file stm32f4xx_hal_msp.c:
  * File Name          : stm32f4xx_hal_msp.c
  * Description        : This file provides code for the MSP Initialization
  *                      and de-Initialization codes.
  * @attention
#include "main.h"
/* USER CODE BEGIN TD */
/* USER CODE END TD */
/* USER CODE BEGIN Define */
/* USER CODE END Define */
/* USER CODE BEGIN Macro */
/* USER CODE END Macro */
/* External functions --------------------------------------------------------*/
/* USER CODE BEGIN ExternalFunctions */
/* USER CODE END ExternalFunctions */
  * Initializes the Global MSP.
void HAL_MspInit(void)
  /* USER CODE BEGIN MspInit 0 */
  /* USER CODE END MspInit 0 */
  __HAL_RCC_SYSCFG_CLK_ENABLE();
  HAL_NVIC_SetPriorityGrouping(NVIC_PRIORITYGROUP_0);
  /* System interrupt init*/
  /* USER CODE BEGIN MspInit 1 */
  /* USER CODE END MspInit 1 */
* @brief SPI MSP Initialization
* This function configures the hardware resources used in this example
* @param hspi: SPI handle pointer
* @retval None
void HAL_SPI_MspInit(SPI_HandleTypeDef* hspi)
  if(hspi->Instance==SPI2)
  /* USER CODE BEGIN SPI2_MspInit 0 */
  /* USER CODE END SPI2_MspInit 0 */
    /* Peripheral clock enable */
    __HAL_RCC_SPI2_CLK_ENABLE();
    /**SPI2 GPIO Configuration
    PB12     ------> SPI2_NSS
    PB13     ------> SPI2_SCK
    PB14     ------> SPI2_MISO
    PB15     ------> SPI2_MOSI
    GPIO_InitStruct.Pin = GPIO_PIN_12;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_PULLUP;
    GPIO_InitStruct.Alternate = GPIO_AF5_SPI2;
    HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  /* USER CODE BEGIN SPI2_MspInit 1 */
  /* USER CODE END SPI2_MspInit 1 */
* @brief SPI MSP De-Initialization
* This function freeze the hardware resources used in this example
* @retval None
void HAL_SPI_MspDeInit(SPI_HandleTypeDef* hspi)
  /* USER CODE BEGIN SPI2_MspDeInit 0 */
  /* USER CODE END SPI2_MspDeInit 0 */
    /* Peripheral clock disable */
    __HAL_RCC_SPI2_CLK_DISABLE();
    HAL_GPIO_DeInit(GPIOB, GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15);
  /* USER CODE BEGIN SPI2_MspDeInit 1 */
  /* USER CODE END SPI2_MspDeInit 1 */
* @brief UART MSP Initialization
* @param huart: UART handle pointer
* @retval None
void HAL_UART_MspInit(UART_HandleTypeDef* huart)
  if(huart->Instance==USART2)
  /* USER CODE BEGIN USART2_MspInit 0 */
  /* USER CODE END USART2_MspInit 0 */
    __HAL_RCC_USART2_CLK_ENABLE();
    /**USART2 GPIO Configuration
    PA2     ------> USART2_TX
    PA3     ------> USART2_RX
    GPIO_InitStruct.Pin = USART_TX_Pin|USART_RX_Pin;
    GPIO_InitStruct.Alternate = GPIO_AF7_USART2;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  /* USER CODE BEGIN USART2_MspInit 1 */
  /* USER CODE END USART2_MspInit 1 */
* @brief UART MSP De-Initialization
* @retval None
void HAL_UART_MspDeInit(UART_HandleTypeDef* huart)
  /* USER CODE BEGIN USART2_MspDeInit 0 */
  /* USER CODE END USART2_MspDeInit 0 */
    __HAL_RCC_USART2_CLK_DISABLE();
    HAL_GPIO_DeInit(GPIOA, USART_TX_Pin|USART_RX_Pin);
  /* USER CODE BEGIN USART2_MspDeInit 1 */
  /* USER CODE END USART2_MspDeInit 1 */
RESOLVED: I'm using STM32CubeMX(even in STM32CubeIDE) and it has only option in settings "GPIO_MODE_AF_PP" but the pin should be set to "GPIO_MODE_OUTPUT_PP". This means that every single time when I will edit peripherals in CubeMX I have to rewrite this option.
My first thoughts were ... ok, no big deal, CubeMX wants there this it's probably has the same functionality... BUT IT DOESN'T!!!
What's an alternate pin function on a microcontroller?
#define  GPIO_MODE_INPUT                        0x00000000U   /*!< Input Floating Mode                   */
#define  GPIO_MODE_OUTPUT_PP                    0x00000001U   /*!< Output Push Pull Mode                 */
#define  GPIO_MODE_OUTPUT_OD                    0x00000011U   /*!< Output Open Drain Mode                */
#define  GPIO_MODE_AF_PP                        0x00000002U   /*!< Alternate Function Push Pull Mode     */
#define  GPIO_MODE_AF_OD                        0x00000012U   /*!< Alternate Function Open Drain Mode    */
CLOSED
  • \$\begingroup\$ I didn't read all your code, but you are calling both UART_Init and SPI_Init. You said you're using SPI? Try commenting out the UART_Init line(s). It maybe that you're putting the library into UART mode by doing that and it's not trying SPI. \$\endgroup\$ – hekete May 26 at 6:32
