I have PCF8563 WAVESHARE board connected to DIGISPARK via I2C. Here is the code:
    #include "Rtc_Pcf8563.h"
/* Demonstration of Rtc_Pcf8563 Set Time.
 * Set the clock to a time then loop over reading time and
 * output the time and date to the serial console.
 * I used a RBBB with Arduino IDE, the pins are mapped a
 * bit differently. Change for your hw
 * SCK - A5, SDA - A4, INT - D3/INT1
 * After loading and starting the sketch, use the serial monitor
 * to see the clock output.
 * setup:  see Pcf8563 data sheet.
 *         1x 10Kohm pullup on Pin3 INT
 *         No pullups on Pin5 or Pin6 (I2C internals used)
 *         1x 0.1pf on power
 *         1x 32khz chrystal
 * Joe Robertson, jmr
 * orbitalair@bellsouth.net
#include <TinyPinChange.h>
//#include <Wire.h>
//init the real time clock
Rtc_Pcf8563 rtc;
uint8_t VirtualPortNb;
volatile bool flag =0 ;
void setup()
  VirtualPortNb = TinyPinChange_RegisterIsr(3,  wakeUpRTC);
  pinMode(3, INPUT);           // set pin to input
  pinMode(1, OUTPUT);
  //clear out the registers
  rtc.initClock();
  //set a time to start with.
  //day, weekday, month, century(1=1900, 0=2000), year(0-99)
  rtc.setDate(27, 1, 5, 0, 19);
  delay(100);
  //hr, min, sec
  rtc.setTime(19, 43, 45);
  rtc.setAlarm( 19, 44, 99, 99 );
  for( int i=0; i<3; i++ ){
      digitalWrite( 1, 1);
      delay(600);
      digitalWrite( 1, 0);
      delay(600);
  TinyPinChange_EnablePin( 3 );
void loop(){
  if (flag==1){
    flag = 0;
    for( int i=0; i<10; i++ ){
      delay(300);
      delay(300);
void wakeUpRTC(){
  flag = 1;
There are 10k pullup resistors on SCL, SDA and INT pins. INT is Open Drain
Problem is that ATTINY does not detect external interrupt. Strange thing is that when I measure voltage on INT pin there is 3V instead od 5.2V (VCC). When I run very similar code on Arduino UNO, everything works perfect.
Any ideas?
