I have some memory address 0x00000100 that I want to read from. The lower 4 bits read from this address indicates the states of 4 buttons - So bit 0 shows the state of button 0, bit 1 shows the state of button 1, etc. My question is- How can I find determine the state of button 0 and button 1 in assembly language? I want to know when button 0 and button 1 are high.
I am using a MiteFPGA processor, and Xilinx Vivado, on a basys 3 board. I am using the MiteASM assembler.
  • \$\begingroup\$ If button 1 is high I want t increment a counter, whereas if button 0 is high, I want to reset it. I think I have the other details of assembly language sorted, but it's this reading from particular bytes of memory address 0x100 that is getting me. \$\endgroup\$ – Angela May 27 at 23:21
  • \$\begingroup\$ You don't want to read specific bytes, but specific bits. I can't find information on your MiteFPGA CPU. Please supply some documentation. \$\endgroup\$ – Janka May 27 at 23:54
    \$\begingroup\$ The typical way is to read the byte with the interesting bits into an ALU register, then bit-test on them. Depending on the CPU, it may also be possible to have this bit-test done directly with memory, or there aren't bit-test instructions which means you had to AND the ALU register against a mask and check the zero flag. \$\endgroup\$ – Janka May 27 at 23:55
You want to use the 'lw' operation (load word) to grab 0x100 it has the format 'lw $rt SignImm($rs)'. Then you need to do an 'and' operation with the appropriate bit mask to extract the state of that bit. The and op is in the form 'and $rd, $rs, $rt'.
So say the bottom 4 bits are: 1001, and you AND that with 1000. The result will be 1000, telling you that the 4th bit is a 1.
