So I used a common 230vAC to 12vDc (1AMP) wall adapter with dc jack like thisenter image description here
and converted to 5v using a dc to dc buck converter same as based on lm2596s enter image description here
But the adapter LED starts blinking (normally the LED should just light up ) even if the output is not connected to anything.
My Question: Why is it happening and what can I do to overcome this issue?
update 1: I have tried using a 12vDC 20Amps SMPS and it works well.But not with the 12VDC 1Amps adapter
closed as unclear what you're asking by Justme, Neil_UK, Bimpelrekkie, Dave Tweed May 28 at 12:38
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
Since the input capacitor has a low ESR the surge current may be up to 12V/ESR.
If the supply starts up with the Buck connected then a slow start might work with a suitable ICL, Inrush Current Limiter.
Ic = C dV/dt Choose 1A or get a variety of values with a 12~22 Ohm minimum R @ 25°C
TI's standard design shows 27uF 40 mOhm for Cin. Thus if the 12V output is cycling On and OFF with the Buck regulator connected, 12V/40mOhm = 300A ( in theory ) but in practice limited by supply.
Recommendation:
  • Use a 1A ICL for a 1A source.
  • use a DC source with a soft-start and larger surge capacity such as a 19V 65W Laptop charger.
    \$\begingroup\$ what software did you use to create the schematic and waveform? \$\endgroup\$ – Amrith May 28 at 11:25
    \$\begingroup\$ so @ Sunnyskyguy ,Your point is that if I add ICL I can prevent the blinking(indicating high current flow).Also can you please explain the waveform Thank you very much for your answer \$\endgroup\$ – Amrith May 28 at 11:35
    \$\begingroup\$ @Amrith The schematic/waveform are probably made on TI's webench \$\endgroup\$ – Huisman May 28 at 12:32
