I have some prototype boards that I would like to modify. The modification includes removing a section of circuit and replacing it with another circuit. My theory on how to do this is to make an adapter board that will hold my new circuit that will have castellated holes on the perimeter. The perimeter holes will align with existing SMD pads on the main board in order to make the necessary connections.
My question is are there recommended land patterns for castellated holes that I could use to guide the design of my adapter board? In this case I would be designing the castellated holes to match existing land patterns. Of course this is not optimal but I hope that for a prototype it will work. Most of the mounting points on the main board are one side of 0402 resistor lands. I'm guessing that I should use a hole that is slightly smaller than the existing pad. For example, to connect to a 0.024" square pad I'll use a 0.020" castellated hole. Does this sound reasonable?
Thanks.
Castellated boards okay and are good if the system is area constrained. If there are many pins, rework can take a while. If the changes in prototype board are small, I would look at doing BOM variants, prototyping on a breadboard if you can get discrete components (or on an eval board), or maybe a ribbon cable connector between two boards.
Here are some notes on castellations.
  1. Make the pad on the main board longer so some of it extends out past the via. The extra room gives you a place to put a solder tip when soldering. If the pad was the same size as the 'via' of the castellation, it is directly under and hard to solder. See the picture on this page, https://learn.sparkfun.com/tutorials/how-to-solder-castellated-mounting-holes/all, how the pad overshoots a lot.
  2. Use thermal vias on the main board for any signal connected to a plane. Otherwise, soldering the castellation can be difficult as it takes a long time to heat.
  3. When soldering, tack one corner, then make sure you are completely aligned. For the rest, heat the pad and bottom of the castellation first, then feed the solder in.
  4. When desoldering, be careful to not pull out the pad on the main board. This can happen if you lift up on the PCBA before everything is desoldered. Reflow hot air stations are good if the PCBA is small enough.
  • \$\begingroup\$ I want to do this so that I can use the remainder of the prototype board (with the offending section replaced with a better functioning version) without redesigning it. I will be soldering with hot air, so I think the size of the pad will not be as much of an issue. \$\endgroup\$
    – cholz
    Commented May 28, 2019 at 13:32
