I'm trying to understand the proper biasing procedure of a cascode distributed amplifier part that requires three power supplies. A positive drain-source VDD, a negative gate-source VGG1, and a second, positive gate-source VGG2.
The recommended biasing procedure is for the bottom MESFET VGG1 to be supplied, then the drain-source VDD, and finally the top MESFET VGG2.
I don't know much about amplifier operation, I was tasked to document the proper biasing procedure for parts and determine if there will be an issue. Case in point the VGG2 may be supplied by a linear regulator that's always on while VGG1 and VDD will be controllable. I want to understand what the ramifications of having VGG2 always being on
***EXTRA: I could also use help in trying to model the situation in ADS to have a visual representation of the problem.
In order for the MESFET \$\mathrm{FET_1}\$ to work in saturation region, you should require that $$ |V_{DS_\mathrm{FET_1}}|\ge |V_{P_\mathrm{\,FET_1}}|+|V_{GS_\mathrm{FET_1}}|, \label{1}\tag{1} $$ where \$V_{P_\mathrm{\,FET_1}}\$ is the pinch off (threshold) gate-source voltage of the MESFET. This implies that the quiescent value of \$V_{GG_2}\$ must be chosen in such a way that \eqref{1} is satisfied, and in turn this implies that $$ V_{GG_2}\gg V_\gamma, $$ where \$V_\gamma\$ is the threshold voltage of the \$\mathrm{FET_2}\$ Gate-Source GaAs Schottky junction: normally, this is not a problem since when \$V_{DS_\mathrm{FET_1}}\$ is at its quiescent value \$V_{DSQ_\mathrm{FET_1}}\$, then $$ V_{GSQ_\mathrm{FET_2}}=V_{GG_2}-V_{DSQ_\mathrm{FET_1}}<0 $$ However, if you apply \$V_{GG_2}\$ before applying \$V_{GG_1}\$ then, since \$V_{DS_\mathrm{FET_1}}\$ is still nearly zero, the \$\mathrm{FET_2}\$ Gate-Source GaAs Schottky junction would became forward biased with a high value of gate current \$I_{G_\mathrm{FET_2}}\$ which would permanently damage the device: in sum in order to avoid permanent damages to the MESFETs, it is better to follow the recommended biasing sequence.
  • \$\begingroup\$ Is it possible use a negative Vss1 so you can cascade Vdd2 at the same DC voltage to the next Vgg in to make a distributed amplifier? Or is DC biasing isolated between stages \$\endgroup\$ – Sunnyskyguy EE75 May 28 at 21:28
  • \$\begingroup\$ Since \$V_{GSQ_\mathrm{FET_1}}\$ is usually <0 for MESFETs, it is possible to use a positive \$V_{SS_1}\$ instead of a negative \$V_{GG_1}\$: to my knowledge, DC biasing between RF/MW stages, need not to be isolated. However, years ago \$V_{SS}\$ biasing was not advocated because it was difficult to realize a source decoupling network with adequate low impedance at high frequency: this was especially true for low noise stages. \$\endgroup\$ – Daniele Tampieri May 29 at 5:53
    \$\begingroup\$ @DanieleTampieri Thank you very much for your response and breaking it down for me. I understand to an extent where I feel I can document the issue and go forward with looking at options to fix it. \$\endgroup\$ – aj_intern2019 May 29 at 11:46
  • \$\begingroup\$ @aj_intern2019 You are welcome. And if you find my answer useful, please consider upvoting and accepting it. \$\endgroup\$ – Daniele Tampieri May 29 at 11:48
  • \$\begingroup\$ @DanieleTampieri I have upvoted and accepted your answer. I do not have enough points for the upvote to display however. But again I appreciate your response. Have a nice day. \$\endgroup\$ – aj_intern2019 May 29 at 11:52
