I have a board with three 32 input analog multiplexers, along with more components, connected to a 96 way DIN connector. How do I manually tell the autorouter to select only the muxers signals? I tried "AUTO U1_S[1..32]" for the first muxer but apparently eagle bugs out and select only up to U1_S3, ignoring it is actually 32 instead of 3.
I tried to select them from the design manager but it doesn't seem to care at all an routes the whole board.
It is a bug or a feature and I'm doing it wrong? I know I can manually click all 96 wires but... I would have to do it every single time and that's not cool.
All three muxers follow the same naming schema, as U1_S1..U1_S32, U2_S1..U1_S32..., etc
Ignore the fact that the autorouter is evil, that it creates weird traces and so.. but routing a 96way 3 row DIN connector is quite tricky for me and the autorouter already does the 100% of the board, but I'd like to try "guiding" it selectively.
I'm learning how to do it on the go, so please be kind. Also I'm aware that this is not a DIL atmega board with headers. If I need to write down all 96 nets and copy and paste from notepad...that's ok too but if there's a more human friendly obscure way the better.
Thanks
