Today is my first day on FreeRTOS. I want to use it in STM32F103 for simple task handling as reading data from analog sensor and sending remotely using GSM module.
I want to know what are the do's and don'ts of writing a good task in FreeRTOS? Specifically is it allowed to write a blocking code, for() loop while() loop, inside a task?
    \$\begingroup\$ You should read a book on RTOS usage. \$\endgroup\$
    – Jeroen3
    May 30, 2019 at 8:58
    \$\begingroup\$ See this FreeRTOS article on tasks. You basicly should always write your tasks as infinite loops. \$\endgroup\$
    – olltsu
    May 30, 2019 at 9:25
  • \$\begingroup\$ Judging by this and your other question, i'm not sure you know what a task is, or what an OS is useful for. \$\endgroup\$
    – brhans
    May 30, 2019 at 11:16
It depends a little bit on what you're implementing but as mentioned in the comments as tasks usually handle/emit reocurring events they all should contain an infinit loop so this is not a don't.
What you should keep in mind when introducing multiple tasks is the required processing time and the fact that a context switch requires resources and processing time as well. To reduce unecessary context switching you shouldn't use normal wait loops in your tasks as you might would do in a normal single threaded application, use the delay functions provided by the FreeRTOS instead to set the task asleep.
Further, as you cannot control when a context switch happens, don't forget to protect any shared resources with mutexes.
