I do not want to rotate the parts (that is easy by selecting all and click on rotate icon), only the view.
1\$\begingroup\$ Rotate or flip/mirror? \$\endgroup\$– Jeroen3Commented May 30, 2019 at 9:48
\$\begingroup\$ Not mirror, but rotate 90, 180 or 270 degrees because I have a lot of harness connected and can not rotate the PCB so it is difficult to find components or specific pin in a large connector \$\endgroup\$– mathengineerCommented May 30, 2019 at 19:03
\$\begingroup\$ "...not rotate the PCB so it is difficult to find components or specific pin in a large connector " - What has the connector size got to do with the PCB view? \$\endgroup\$– Bruce AbbottCommented May 30, 2019 at 21:31
Add a comment
1 Answer
This feature is not possible.
It has not been implemented.
https://forums.autodesk.com/t5/eagle-forum/feature-request-turn-eagle-view/td-p/8980757
