Let us say we want to configure a 16-bit timer to generate an interrupt every 1 second with a clock running at 8 MHz.
We can use several pair of values for the period and prescaler. Let us take the two extremes:
  • prescaler = 125 and period = 64000,
  • prescaler = 64000 and period = 125.
Is it better to take one of the two pair of values regarding the MCU load and power consumption?
  • \$\begingroup\$ I would not think of a measurable difference, but it would be an interesting experiment which is easy to perform. \$\endgroup\$ – Eugene Sh. May 30 '19 at 16:18
  • \$\begingroup\$ When each FF toggles, you'll have about 1mA of shoot-thru current for about 100 picoseconds (your mileage will vary, based on VDD, circuit, technology, etc) \$\endgroup\$ – analogsystemsrf May 30 '19 at 17:11
  • \$\begingroup\$ The biggest win would be not clocking your entire chip at 8 MHz when not necessary. \$\endgroup\$ – Chris Stratton May 30 '19 at 17:16
Probably no difference at all, since the same flip-flop design is likely used in both places. Whichever way you configure it, you have the same number of flip-flops toggling at the same rates.
  • \$\begingroup\$ What is confusing me is that, for one period, the counter register will be written N times, N being the period value. As a consequence there will be less register writings than if we took a higher value for the period. \$\endgroup\$ – Mat.R May 30 '19 at 17:08
  • \$\begingroup\$ @Mat.R the prescalars are effectively counter registers too. There may be a tiny difference, but it's really unlikely to be of consequenece. \$\endgroup\$ – Chris Stratton May 30 '19 at 17:16
