I have a board that has fairly high working voltages up to 100V with small clearances down to 12 mil between the high voltage and ground or low voltage nets. This is unavoidable because the whole board is tiny and in some cases the HV and low voltage are adjacent pads on the same component.
This is currently assembled using a water wash cleaning step.
Is it possible to assemble this using no-clean? What are the possible problems with having flux residue on a high voltage board like this? Is it better to clean (with the possible ionic contamination from the detergents) or not clean (with flux residue)?
Also, could I do conformal coating over flux residue? Some references about this: http://www.circuitinsight.com/programs/51472.html https://aimsolder.com/technical-articles/conformal-coating-over-no-clean
Note: In this case, signal integrity (as on high speed boards) is not much of a concern; failure modes involving a high voltage to low voltage net short are. 1mA leakage from 100V to the microcontroller on the board would be bad; even 0.1mA would still result in very abnormal operation, although the board would survive. The board may be exposed to high humidity environments, so there may be condensation, although there wouldn't (normally) be direct water immersion.
    \$\begingroup\$ If you are using a commercial components that normally takes high voltage differences between adjacent pins it might be a good idea to contact the manufacturer directly for their recommendations on flux type and cleaning. Perhaps even the datasheet of the component offers some recommendations. \$\endgroup\$
    – Nedd
    Nov 11, 2019 at 7:46
  • \$\begingroup\$ Well the links you added already answers your (edited) question: it depends. From the interview "Like everything else, in my opinion, it comes down to what is the reliability level of your product?", "The issue is if you haven't perfectly deactivated all that solder paste flux, now you're capturing it. You can make the potential for damage even worse because, virtually all conformal coatings are not completely impervious to water." and "As Jim says, don't be surprised if you find yourself relegated to cleaning that no clean residue off." \$\endgroup\$ Nov 13, 2019 at 7:39
  • \$\begingroup\$ If you want to be save your best bet is use cleaning with a final rinse cleaning step where you monitor the ionic concentration. If you are fine with limited lifetime and aim for low cost go for no clean + coating. How limited your lifetime will be? Who knows. \$\endgroup\$ Nov 13, 2019 at 7:46
  • \$\begingroup\$ The correct answer to this needs more information. Is there a risk to life or property? Can a person touch it? What reliability do you want to achieve? How much energy would be dissipated in the event of a dielectric breakdown? Is it mains connected? If so you will have to meet very specific country-by-country requirements. At 100V it's above all definitions of a 'safe' circuit, but 100v at 1uA is mostly harmless. \$\endgroup\$
    – Jay M
    Nov 15, 2019 at 17:33
7
To the best of my knowledge conformal coating requires very clean surfaces for proper adhesion (see doi: 10.1088/1741-2560/10/3/031002 ). At least in our lab all boards are cleaned using a complex cleaning procedure which has a final "rinsing with deionized water including conductivity monitoring" step (doi: 10.1109/EMBC.2016.7591102 ). For 100V a track clearance of at least 0.2 mm is recommended according to my information so 12 mil = 0.3048 mm should be fine ( http://www.creepage.com/ ). From my experience even the "no clean" (I typically use SMD291 and SMD291AX) can leave some serious amount of residue depending on the used amount which can impact electrical signal quality. At least I observed signal degeneration in HF applications with 0.4 mm BGA ICs. After additional cleaning steps with deflux etc the signals typically normalize.
residuals after using SMD291 and only sloppy mechanical cleaning: residuals after using SMD291 and only fast mechanical cleaning
  • 4
    \$\begingroup\$ Flux residues (and they exist for all types as you note, including 'no-clean' are a major issue in high speed and very dense circuits as well. See kester.com/Portals/0/Documents/Knowledge%20Base/Publications/… for an excellent summary of issues. \$\endgroup\$ Jun 2, 2019 at 13:36
  • \$\begingroup\$ Very interesting publication! I especially like the general overview but the presentation of data is suboptimal. e.g. I can just guess that the y axis in the plots are something like resistance in ohm(?). Many information regarding the test structure dimensions etc are lacking, which renders reproducting and understanding almost impossible and almost all pictures are without a proper scale. This is really a pitty considering the relevance of this topic. \$\endgroup\$ Jun 2, 2019 at 18:34
    \$\begingroup\$ Apple iMAC's and iPADs were notorious >5 yrs ago for voiding warranty failures from blue moisture dots that changed color to indicate moisture ingress. This was due to the fact they approved the no-clean flux which caused exposed edge copper-rust and thus voided warranty and resulted in functional failures. ( from my investigations) They did not use conformal coatings however, which do need pre-cleaning. \$\endgroup\$ Nov 11, 2019 at 17:01
If you don't clean, the electrolytes in the residual flux could build up conducting anodic filaments between the different potentials, leading to shorts.
  • If you have conformal coating, you absolutely must take care, that the PCB is clean before applying the coating. You have to make sure that the coating dries out. Otherwise the remaining electrolyte "bubbles" under the coating coul lead to CAF.
  • If you do not use conformal coating, I guess the best you can do is to make sure your board is dry and it stays dry. This way the electrolytes can not move and build up a bridge between the potentials.
The company I was working for (automotive industry) had a step in the verification/validation process, where we would put a number of products in a climate chamber 85°C/85%RH in active state (voltage applied) for months to check for conductive anodic filaments. It is a way for you to verify your design and production process.
I think the best solution you can do if your production allows it is
  • cleaning with an alcoholic detergent like isopropanol, if possible with ultrasonic cleaner
  • and as Christian B. mentioned cleaning with deionized water at the end
  • Make sure the board is dry
  • then apply conformal coating in a thin layer
  • and make sure it dries out.
You can find a lot of resources regarding this on google.
Strictly speaking, there is no such thing as a No Clean Solder paste; there are low residue pastes and for low complexity low value boards it may indeed be run through the process without cleaning but I would not do this for a board with relatively high voltages that has to exhibit high reliability.
Before going further on flux, it should be noted that the corrosion of lead free solders (at least the SAC types) is galvanic (I found that during an investigation for a previous company from IEEEXplore research papers) due to dissimilar metal corrosion. This is due to the relative anodic potentials of the metals involved.
In addition to that, lead free solders are more difficult to use than the classic SnPb types (they require a longer time in reflow - hand soldering takes 5 or so seconds compared to a second or so for SnPb); as they are somewhat more difficult (not impossible but more care must be taken for the reflow profile) the possibility of solder splash and flux outgassing is a bit higher.
As your units are destined for high humidity environments for at least some of them (and I assume they are in a relatively normal atmospheric environment apart from the high humidity) then conformal coating seems unavoidable to prevent (or at least inhibit) that corrosion as salts are naturally in the air and will combine with any moisture to create a current path somewhere quite apart from degrading solder joints due to corrosion.
I have had this problem in the past where the cleaning tanks were not clean enough and left salts on the board and the boards were then conformally coated; conformal coat is not a perfect moisture barrier and given sufficient humidity some moisture will end up beneath it but in this case the residues prevented the coating from properly adhering to the PCB.
That particular board had a 50V static inverter to drive an escrow relay in a payphone and the drive transistor shorted out and burned a hole in the board (the transistor fell through the hole).
Where residues exist on a PCB, climatic and environmental stress (heating, cooling, vibration) can cause the residues to crack and absorb moisture if left exposed which can induce unfortunate failure modes including electrochemical migration and leakage paths (which you have identified as problematic).
Attempting to conformally coat a board with flux residues can (and probably will) lead to poor coating adhesion and potential delamination of the coating (so there is now a clear moisture ingress path).
Residures cn also, under some circumstances, promote dendrite growth (giving rise to potential localised short circuits).
I would also note that the flux residues themselves are in fact 'salts'; add moisture and you get potential short circuits.
So if you are going to conformally coat a unit, you really have no choice but to thoroughly clean the board post assembly with the last stage being a deionised water bath and then a slow bake to ensure all (well, the vast majority of of it) moisture has been expelled prior to conformal coat.
Further reading.
