What are the hardware tests for Ethernet?
Just need to verify the MII/RMII timing waveform with respect to specifications given in the datasheet.
  • \$\begingroup\$ As far as I'm aware, there isn't nThe timing diagrams should be in the datasheet, connect a logic analyzer to the MII\RMII interface and verify the timing. The measured numbers (rise times, fall times and voltage transition levels should be within the bounds of those listed in the datasheet and spec ebook.pldworld.com/_eBook/-Telecommunications,Networks-/TCPIP/… \$\endgroup\$ – Voltage Spike Jun 5 at 16:50
