My mouse requires AA 1.5 volt batteries to work. I accidentally used a 3.6 volt Li-SOCl2 battery. Now it works fine with the 3.6 volt battery but doesn't work at all with a 1.5 volt AA battery.
I have this mouse and keyboard combi: https://www.microsoft.com/accessories/en-nz/products/keyboards/sculpt-ergonomic-desktop/l5v-00027
How is this even possible?
Perhaps some traces are burnt enough so that no current can flow through them with 1.5 volt?
closed as off-topic by brhans, Elliot Alderson, RoyC, DoxyLover, Phil G Jun 11 at 21:26
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the repair of consumer electronics, appliances, or other devices must involve specific troubleshooting steps and demonstrate a good understanding of the underlying design of the device being repaired. See also: Is asking on how to fix a faulty circuit on topic?" – brhans, Elliot Alderson, RoyC, DoxyLover, Phil G
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ If you would burn a trace, an additional 2 V over what's specified would not be enough. We can only guess, but some front-end LDO could be toast and you are now feeding it though some body diode. You need to open it and probe it to find out. \$\endgroup\$ – winny Jun 3 at 7:51
Without knowing the design, what really happened can only be guessed at.
I'm assuming that the mouse originally worked with only one 1.5 V AA cell, I mean, that it did not require two cells in series.
You probably damaged the DCDC boost converter chip inside the mouse. This boost converter is needed as 1.5 V usually isn't enough to power all circuits. This is an example of a typical boost converter circuit:
Note the inductor L1 and the diode D1, they are nearly always present in boost converters. It is possible that D1 is an internal (on chip) transistor with a diode in parallel.
If the IC is damaged and doesn't switch but L1 and D1 are intact then applying 3.6 V at the input will result in about 3 V at the output. That could be enough to power all circuits and make the mouse operate.
