I'm still an inexpirient and I'm configuring the PIC, through MCC (Microship Code Configurator)
So i set in the MCC a TMR1:
The configuration for the System Module:
I want the clock to tick at 8 us.
That doesn't seem to be happening, so i made the TMR1_CallBack send an alternate 0 and 1 to a port of the pic and watched the signal with an oscilloscope. There i see that it changes every ~28us.
enter image description here note: this image is outdated, with primary oscillator each transition is 28us it doesnt go below that.
The Timers a 16 bit timers.
The code from the tmr1.c where i toggle the pin:
  TMR1 Generated Driver API Source File
  @Company
    Microchip Technology Inc.
  @File Name
    tmr1.c
  @Summary
    This is the generated source file for the TMR1 driver using PIC32MX MCUs
  @Description
    This source file provides APIs for driver for TMR1.
    Generation Information :
        Product Revision  :  PIC32MX MCUs - pic32mx : v1.35
        Device            :  PIC32MX470F512L
        Driver Version    :  0.5
    The generated drivers are tested against the following:
        Compiler          :  XC32 1.42
        MPLAB             :  MPLAB X 3.55
    (c) 2016 Microchip Technology Inc. and its subsidiaries. You may use this
    software and any derivatives exclusively with Microchip products.
    THIS SOFTWARE IS SUPPLIED BY MICROCHIP "AS IS". NO WARRANTIES, WHETHER
    EXPRESS, IMPLIED OR STATUTORY, APPLY TO THIS SOFTWARE, INCLUDING ANY IMPLIED
    WARRANTIES OF NON-INFRINGEMENT, MERCHANTABILITY, AND FITNESS FOR A
    PARTICULAR PURPOSE, OR ITS INTERACTION WITH MICROCHIP PRODUCTS, COMBINATION
    WITH ANY OTHER PRODUCTS, OR USE IN ANY APPLICATION.
    IN NO EVENT WILL MICROCHIP BE LIABLE FOR ANY INDIRECT, SPECIAL, PUNITIVE,
    INCIDENTAL OR CONSEQUENTIAL LOSS, DAMAGE, COST OR EXPENSE OF ANY KIND
    WHATSOEVER RELATED TO THE SOFTWARE, HOWEVER CAUSED, EVEN IF MICROCHIP HAS
    BEEN ADVISED OF THE POSSIBILITY OR THE DAMAGES ARE FORESEEABLE. TO THE
    FULLEST EXTENT ALLOWED BY LAW, MICROCHIP'S TOTAL LIABILITY ON ALL CLAIMS IN
    ANY WAY RELATED TO THIS SOFTWARE WILL NOT EXCEED THE AMOUNT OF FEES, IF ANY,
    THAT YOU HAVE PAID DIRECTLY TO MICROCHIP FOR THIS SOFTWARE.
    MICROCHIP PROVIDES THIS SOFTWARE CONDITIONALLY UPON YOUR ACCEPTANCE OF THESE
    TERMS.
  Section: Included Files
#include <xc.h>
#include "tmr1.h"
#include "pin_manager.h"
  Section: Data Type Definitions
/** TMR Driver Hardware Instance Object
  @Summary
    Defines the object required for the maintainence of the hardware instance.
  @Description
    This defines the object required for the maintainence of the hardware
    instance. This object exists once per hardware instance of the peripheral.
  Remarks:
    None.
typedef struct _TMR_OBJ_STRUCT
    /* Timer Elapsed */
    bool                                                    timerElapsed;
    /*Software Counter value*/
    uint8_t                                                 count;
} TMR_OBJ;
static TMR_OBJ tmr1_obj;
  Section: Driver Interface
void TMR1_Initialize (void)
    // TMR1 0;
    TMR1 = 0x0;
    // Period = 0.000008 s; Frequency = 32000000 Hz; PR1 256;
    PR1 = 0x100;
    // TCKPS 1:1; TWDIS disabled; TCS PBCLK; SIDL disabled; TSYNC disabled; TGATE disabled; ON enabled;
    T1CON = 0x8000;
    IFS0CLR= 1 << _IFS0_T1IF_POSITION;
    IEC0bits.T1IE = true;
    tmr1_obj.timerElapsed = false;
void __ISR(_TIMER_1_VECTOR, IPL1AUTO) _T1Interrupt (  )
    //***User Area Begin
    // ticker function call;
    // ticker is 1 -> Callback function gets called everytime this ISR executes
    TMR1_CallBack();
    //***User Area End
    tmr1_obj.count++;
    tmr1_obj.timerElapsed = true;
void TMR1_Period16BitSet( uint16_t value )
    /* Update the counter values */
    PR1 = value;
    /* Reset the status information */
uint16_t TMR1_Period16BitGet( void )
    return( PR1 );
void TMR1_Counter16BitSet ( uint16_t value )
    TMR1 = value;
uint16_t TMR1_Counter16BitGet( void )
    return( TMR1 );
void __attribute__ ((weak)) TMR1_CallBack(void)
    // Add your custom callback code here
    IO_RA7_Toggle();
void TMR1_Start( void )
    /*Enable the interrupt*/
    /* Start the Timer */
    T1CONbits.ON = 1;
void TMR1_Stop( void )
    /* Stop the Timer */
    T1CONbits.ON = false;
    /*Disable the interrupt*/
    IEC0bits.T1IE = false;
bool TMR1_GetElapsedThenClear(void)
    bool status;
    status = tmr1_obj.timerElapsed;
    if(status == true)
    return status;
int TMR1_SoftwareCounterGet(void)
    return tmr1_obj.count;
void TMR1_SoftwareCounterClear(void)
    tmr1_obj.count = 0;
 End of File
The code of main:
#include "stdio.h"
#include <xc.h>
#include "mcc_generated_files/mcc.h"
void main(void)
    // initialize the device
    SYSTEM_Initialize();
    LED_GREEN_Toggle();
    while (1)
How can i do it?
  • \$\begingroup\$ Please show your code. The Timer normally always increment. \$\endgroup\$ – Mike Jun 3 '19 at 11:50
  • \$\begingroup\$ @Mike hi, have i provived enough information now? \$\endgroup\$ – Nmaster88 Jun 3 '19 at 12:01
  • \$\begingroup\$ Show the code from the ISR where you toggle the pin \$\endgroup\$ – Mike Jun 3 '19 at 12:07
  • \$\begingroup\$ @Mike its just a simple toggle \$\endgroup\$ – Nmaster88 Jun 3 '19 at 13:02
  • \$\begingroup\$ @Mike i've added all the code of tmr1.c \$\endgroup\$ – Nmaster88 Jun 3 '19 at 13:16
