I would like to use a DC power supply to as a source voltage to a sensor and a waveform generator(33120A) to give another input to the sensor. I would like to know how can I make a common ground connection between the DC power supply(E3631A) and the waveform generator.
    \$\begingroup\$ Connect the ground pins together? \$\endgroup\$ – MadHatter Jun 4 '19 at 0:18
  • \$\begingroup\$ It doesn't really matter unless your trying to get sub 1mV measurments, what are you trying to achieve? What is your sensor? \$\endgroup\$ – Voltage Spike Jun 4 '19 at 1:41
