Hi there engineers and electronic experts, I'm doing some research about regenerative power from BLDC motor three phase. Motor is 1000W rated, with 3 wires for three phase output.
The idea is to use a Cockcroft Walton Voltage Multiplier to increase voltage supplied by motor to a DC useful voltage, than charge some cells.
Do you think I can use this voltage multiplier to convert voltage generated by motor to a DC useful voltage multiplied?
Any help is welcome
Thanks for reading.
  • \$\begingroup\$ By 'regenerative' do you mean for example when braking a battery-powered traction motor? \$\endgroup\$ – Bruce Abbott Jun 3 '19 at 23:35
  • \$\begingroup\$ Unless you compute the conversion of power and match RPM, source impedance to load and match voltage battery with a CC/CV regulator , it’s probably time well wasted learning these requirements. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jun 4 '19 at 4:03
  • \$\begingroup\$ Use a boost convertor instead. Voltage multipliers are a great idea but not when it comes to handling power. \$\endgroup\$ – Brian Drummond Jun 4 '19 at 7:32
