I'm connecting a Crystal SMD of 32 MHz to the OSC1 and OSC2 pins of a pic.
When doing the configurations for the pic, inside System Module on clock source i have there some options, including primary oscillator, external oscillator, and others.
I've read in some place that it is a Primary oscillator, but the logic on my mind says that it's external, which is right?
The pic in cause is PIC32MX470F512LT
An external clock or oscillator is a (usually square wave) signal which is generated by some other circuit.
Your setup is a Primary oscillator as the clock is generated locally by the combination of the PIC uC and the crystal.
So choose: Primary oscillator.
  • \$\begingroup\$ Thank you, most of sources i've read point to that. Thanks for clarification. \$\endgroup\$
    – Nmaster88
    Jun 4, 2019 at 9:26
