I am trying to make an indicator that shows whether or not there is a load in the circuit, and if the mosfet is working properly.
I have come up with the following circuit, but I am not sure current will continue to flow through the LED if the MOSFET opens.
R9 may be an inductive load (with diode of course) with resistance about 100 Ohms and R10 should be lower.
I think when the MOSFET fully opens it will short-circuit the LED.
Will current still flow when the MOSFET is fully turned on?
