I was looking at the datasheet of the THAT 1510 mic preamp IC, they suggest the following application circuit:
In the datasheet it says that the T network formed by R1, R2, and R7 gives a common mode input impedance of R1+2R7 = 45K to the right of the coupling capacitors (thats without counting R3, R4, R5 and R6), however I dont know how they got the 45K figure.
According to my analysis a common mode input voltage is the one applied to both inputs, something like this:
In that case it is clearly seen that R1 and R2 are in parallel and both are in series with R7, so the common-mode impedance should be 22500 ohms, what am I doing wrong?
Also, just for the sake of argument, the differential input impedance should be around 2K.
Nothing! The datasheet is wrong. (Yeah, that happens, we're humans and all make mistakes).
The common mode impedance is R1//R2 + R7 = R1 / 2 + R7 = 22.5 kohm.
I think the "2" for placing two resistors in parallel (R1 and R2) somehow got attached to R7 in the datasheet resulting in a wrong value.
