I am trying to build this circuit here: https://www.youtube.com/watch?v=AZb4NLXx1aM
But instead of using the same timer setup I am using this:
When I connect the ground pin of the CPU, the LED starts blinking very fast and the CPU begins to overheat.
Note: I do have the correct pins connected (ground, power, clk), and the 555 timer works perfect without the ground plugged in.
