I have a SMD device that I am am trying to identify. S2 device
Can anyone point me to a manufacturer? Probably a resistor but I am not sure. Any help would be appreciated.
The scale bar in the picture is not correct
    \$\begingroup\$ Looks like a diode to me \$\endgroup\$ – Chris Fernandez Jun 6 '19 at 20:52
  • \$\begingroup\$ Can you get a DMM on diode mode on that thing? \$\endgroup\$ – Voltage Spike Jun 6 '19 at 20:58
  • \$\begingroup\$ There are some varactor diodes in a similar looking package & marking. What's the function of the circuit? \$\endgroup\$ – Spehro Pefhany Jun 6 '19 at 22:38
  • \$\begingroup\$ The circuit board is an LCD driver board. I always thought diodes had a polarity mark of some sort; I'll probe and do some tests. \$\endgroup\$ – Robert Tufts Jun 7 '19 at 22:09
  • \$\begingroup\$ I suspect that vague dotted stripe on the left is intended to be the polarity marking... \$\endgroup\$ – brhans Jun 7 '19 at 22:23
Taiwan Semiconductor makes a 1N4448 diode in a SOD-323F package with 'S2' marking.
Some accurate measurements on the package would help to confirm.
| improve this answer | |
  • \$\begingroup\$ I will contact them thanks. \$\endgroup\$ – Robert Tufts Jun 7 '19 at 22:09
https://www.amazon.com/huaban-CMS02-Marking-Schottky-Barrier/dp/B01MEHIITR
Thanks to all that responded it appears to be a huaban CMS02 M-FLAT Marking S2 Schottky Barrier Diode
