I'm trying to derive the transfer function of a summing integrator for use in a feedback circuit. The single input and double input integrators are shown below.
An integrator with one input is derived such that:
$$V_{\text{OUT}} = -\frac{1}{RC}\int V_{\text{IN}}dt$$
For gain in the frequency domain, this becomes:
$$\left\lvert\frac{V_{\text{OUT}}}{V_{\text{IN}}}\right\rvert = \frac{1}{\omega R C}$$
So because at the negative terminal of the opamp, these input voltages are summed, the summing integrator transfer function is:
$$V_{\text{OUT}} = -\frac{1}{R_{\text{fb}}C}\int V_{\text{fb}}dt - \frac{1}{R_1C}\int V_{\text{IN}}dt$$
My question is, in the frequency domain, does this simply become:
$$\left\lvert\frac{V_{\text{OUT}}}{V_{\text{I}}}\right\rvert = \frac{1}{\omega R_{\text{FB}} C} + \frac{1}{\omega R_{\text{IN}} C}$$
Where \$V_{\text{I}} = V_{\text{FB}} + V_{\text{IN}}\$ and the output is 180 degrees shifted (90 degrees + 90 degrees).
