LNBF is made of horn antenna, waveguide, half/quarter wave dipole and some circuitry on PCB. I know Horn antenna is used to match impedance between waveguide and free space but my doubt is, why we dont use half/quarter dipole antenna directly instead of using horn antenna, waveguide and all?
Dipoles are linearly polarized. Most satellite signals are circularly polarized, this allows satellites to rotate, eliminates alignment issues on the ground (instead of horizontal and vertical linear polarization you would end up with n/s and e/w linear polarization, or whatever axis was used). Also, signals can get rotated when traversing the ionosphere which does not affect circularly polarized signals (they still get rotated but the hand-ness of the circular polarization does not change).
Also, many satellites transmit separate signals with right hand and left hand polarization. A dipole would mix both signals which is not desirable.
There are some satellites with linear polarization (probably mostly older satellites in geosynchronous orbits).
  • \$\begingroup\$ but inside the waveguide, there is 1 or more pins which act as dipole then what is the need of that? \$\endgroup\$
    – Prerna
    Jun 7, 2019 at 6:49
  • \$\begingroup\$ Those pins are usually quarter wave feeds. Two feeds, carefully arranged generates circular polarization. It is also possible to use a single feed with a bend and various other structures to generate circular polarization. \$\endgroup\$ Jun 7, 2019 at 8:53
