When I try to prove that Vce for saturation is below .2V and I take npn transistor I simply consider emitter to be at 0V and thus base emitter junction being forward biased base gets a voltage of (.7 V + x) where x is positive constant then to forward bias base collector junction I will have to have forward Voltage of at least .8V so collector voltage becomes .7v+x-.8v+z where z is a positive constant and x is greater then z so collector voltage should become -.1V+(x+z) thus What I am getting is Vce should be greater then -.1V When follow same procedure for PNP I get Vce greater then .1V which is totally in coherent with <.2V What I am doing wrong please help
  • \$\begingroup\$ if you want to estimate Vce with a part number, it is helpful to use Vce(sat) @ Ic=10*Ib then go from there if you know the actual ratio and actual load current as the bulk resistance causes a linear rise in Vce/Ic The actual Vbe depends on these values and could be 0.6V if Ic is 1mA and Vce=50mV \$\endgroup\$ Jun 10, 2019 at 1:58
  • \$\begingroup\$ |Vce(sat)| is not necessarily less than 200mV. For example, for 2N4401 it will be >200mV typically if Ic >150mA for Ic/Ib = 10 and it will never get less than about 400mV at Ic = 500mA regardless of Ib. \$\endgroup\$ Jun 10, 2019 at 2:20
    \$\begingroup\$ @Buzz bee - you are treating this like an algebra problem. BJTs are much more complicated than that. See the Wikipedia article: en.wikipedia.org/wiki/Bipolar_junction_transistor \$\endgroup\$
    – Mattman944
    Jun 10, 2019 at 2:23
  • \$\begingroup\$ This assumption is incorrect: ".7v+x-.8v+z where z is a positive constant". This expression incorrectly models the voltage and current relationships within an NPN BJT, and is the reason your analysis isn't working. (Unrelated comment: For numeric values less than 1, always put a leading zero to the left of the decimal point: CORRECT 0.7, INCORRECT, .7). (Unrelated comment: Please use punctuation marks like commas and periods in your written prose. Your message is very difficult to read and understand because it has no punctuation marks.) \$\endgroup\$ Jun 10, 2019 at 7:50
**if you want to estimate Vce with a part number, it is helpful to use Vce(sat) @ Ic=10*Ib then go from there.
The hFE declines to about 10% of the max linear value at the rated Vce(sat). The Vce(sat)/Ic = Rce is a computed term that is often useful to know for a switch characteristic when choosing a device or a collector load. Rce decreases with increasing base current and collector current when saturated.
The actual Vbe depends on these values and could be 0.6V if Ic is 1mA and Vce=0.06V.
You can also see Rce (typ) @ 25'C at full saturation with Ic/Ib=10 for this part;
Rce=60 Ohms @ Ic=1 mA Vce= 60mV.
Rce= 5 Ohms @ Ic=10 mA Vce= 50mV.
Rce= 1.3 Ohms @ 100mA Vce = 130mV.
Rce = 0.8 Ohms @ 500 mA Vce= 400mV.
This trend is common but the ohmic scale reduces for higher power switching transistors.
2N4401 example General Purpose Small signal TO92
When operating in the linear region the collector is a high impedance current sink.
