I want to use ESP32 with the STWD100NYWY3F external watchdog timer. Below is my connection diagram.
On WDI with 33 pin, periodic pulses are sent to the watchdog timer. If the timer is not reset, then a low level is sent from WDO to the EN output, which should reset ESP32. EN output is constantly raised to a high level, which should block its operation, as soon as a low level is applied to 32 outputs - the timer starts and controls the system.
Questions:
  1. I correctly understood the principle of operation and the scheme?
  2. Will it work with ESP32 or do I need to change something?
  3. On one of the forums I saw the following:
Is this a problem for ESP?
    \$\begingroup\$ The points raised in the forums are valid. What are the reasons why you don't want to use ESP's internal WDT? \$\endgroup\$ – anrieff Jun 10 at 7:53
  • \$\begingroup\$ ESP32 will be in the zone of interference, as far as I know, it may happen that the internal WDT will not be able to restart ESP. \$\endgroup\$ – Алекс Гарисон Jun 10 at 8:06
    \$\begingroup\$ I'm using an ESP32 in a very demanding application, no issues with the WDT though. Keep in mind that even with the internal WDT (where you'd have it handled by the OS properly during updates/program upload) you'd still need to use a pretty large timeout, e.g. 10 seconds or more. \$\endgroup\$ – anrieff Jun 10 at 10:40
  • \$\begingroup\$ @anrieff Thank you!!! \$\endgroup\$ – Алекс Гарисон Jun 12 at 9:19
