I have the following N-JFET DC circuit for which I must find the output voltage \$V_{out}\ = V_D\$ (the drain voltage with respect to ground) when a PWM signal from \$-10V\$ to \$0V\$ is applied to gate. I can solve the circuit when the signal is at \$-10V\$ so I will focus exclusively on the \$0V\$ part.
The circuit is simulated with the PWM signal at \$0V\$ applied to the gate of the JFET, thus explaining the connection between the gate and the source to ground.
I know that \$I_{DSS} = 10mA\$ and the pinch-off voltage \$V_p = -4V\$ and I found that when the PWM signal is at \$-10V\$ the JFET is blocked so \$V_{out} = 10V\$, but I don't understand how I can find the output voltage when PWM signal is at \$0V\$.
I found that if \$V_{out} = |V_p|\$ when \$ V_{GS} = 0V \$ then \$ I_D = I_{DSS}\$, but doing so would result in an impossible voltage drop of a hundred volt on my \$10k \Omega\$ resistor, so I conclude that \$V_{out}\$ must be less than this, thus my JFET should be somewhere in the ohmic region. However, I cannot find the value given by the simulation.
Other given values are \$\lambda\ = 0V^{-1}\$ for the channel length modulation parameter and a temperature of 25 Celsius degree.
Any help would be greatly appreciated.
