Which direction should the diode, cathode or anode, be facing for a car security alarm wire? Below is a diagram.
When the doors are closed, the wires are testing at 10.1 Volts, settings on the system could be set for either negative or positive door trigger input.
A system that tests wires as always on when doors are closed means it's a negative door trigger?
