8
I am taking code from a stm32f0 series and trying to convert it to a stm32l4 series dev kit. I have already changed the necessary addresses and include files that I needed to migrate, but I keep on getting the following errors in the stm32l4xx_hal_uart Files:
../Drivers/STM32L4xx_HAL_Driver/Inc/stm32l4xx_hal.h:610:1: error: unknown type name 'HAL_StatusTypeDef'; did you mean 'HAL_RTCStateTypeDef'? HAL_StatusTypeDef HAL_DeInit(void); ^~~~~~~~~~~~~~~~~
The error appears by this segment of code:
HAL_StatusTypeDef HAL_HalfDuplex_Init(UART_HandleTypeDef *huart);
I have already defined the HAL_UART_MODULE_ENABLED in the stm32l4xx_hal_conf.h and nothing has changed.
What is the cause of this and how can I fix it?
  • \$\begingroup\$ Find the header file that defines a HAL_StatusTypeDef and make sure it gets included. It might help to enable the switch that will have your compiler save the preprocessor output. There really is no magic bullet here. \$\endgroup\$ Jun 11, 2019 at 13:39
  • \$\begingroup\$ I have included it in the header files, that is in the STM32L4xx_HAL_Driver and it still gives me that error, I do not understand by what you mean by enable the switch that will have your compiler save the preprocessor output. \$\endgroup\$
    – user150963
    Jun 11, 2019 at 13:55
  • \$\begingroup\$ Do you have a valid stm32l4xx_hal_conf.h file for your project? You're supposed to take stm32l4xx_hal_conf_template.h, make a copy named just stm32l4xx_hal_conf.h, and then edit it to enable the particular modules you're using. If you've done that properly then all the STM HAL library includes & typedefs should just work... \$\endgroup\$
    – brhans
    Jun 11, 2019 at 17:33
  • \$\begingroup\$ Have you changed the definition of the used controller type in your project settings? \$\endgroup\$
    – A.R.C.
    Jun 12, 2019 at 9:28
  • \$\begingroup\$ I do not understand what you mean by controller type? \$\endgroup\$
    – user150963
    Jun 12, 2019 at 10:31
I just got the same issue but with an STM32F407 microcontroller. Suddently, the build broke and there were 102 errors saying that HAL_StatusTypeDef was unknown. I followed the path to all the includes, and what I saw is that "stm32f4xx_hal_def.h" includes "stm32f4xx.h", which indirectly re-includes "stm32f4xx_hal_def.h" for each device you have enabled in "stm32f4xx_hal_conf.h". Except that each include of "stm32f4xx_hal_conf.h" includes again "stm32f4xx_hal_def.h", but this will fail, as the #define __STM32F4xx_HAL_DEF guards the file of being included twice ! So the conclusion for me was to always include "stm32f4xx.h", and not any intermediate file, as all these circular includes are calling for trouble !
