When using multiple regulators in a chain, is there noise added to the input by the regulator?
If I have a SMPS feeding an LDO, and then another SMPS after the LDO. Is the ripple or noise added to the LDO rail by the downstream regulation?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityWhen using multiple regulators in a chain, is there noise added to the input by the regulator?
This is what I get out of the setup you envision:
SMPS -> VReg* -> SMPS
And your asking about the rail with the * on it.
In this case, the last SMPS will affect the regulation of the Vreg because it is switching current and because the Vreg has source impedance, and cannot respond infinitely fast to regulate the voltage.
The question then becomes, how much does it affect regulation? This information can be found in good voltage regulation products as they display a graph that shows ripple rejection vs frequency. The SMPS has a switching frequency, and the voltage regulator will reject the ripple and the amount in dB can be found and the amount of rejection calculated.
In most cases, I would find it confusing to place an SMPS after a regulator because
