-3
I am designing an electronic project in Eagle PCB software. The project having a 30Pin SSD1306 Oled Display. I searched in the internet for the eagle library and i cloud not find a matching one. The oled is bought from aliexpress: [https://ru.aliexpress.com/item/32706685992.html][1]
Does anyone know the library for this exact display?
  • \$\begingroup\$ Well, when I click the link it says "error 404" (page not found or something)... \$\endgroup\$ – aschipfl Jun 11 '19 at 15:31
  • \$\begingroup\$ Just design your own part! It would only take a few minutes with the Pulsonix software I use. \$\endgroup\$ – Leon Heller Jun 11 '19 at 15:38
-1
Is this the part?
http://www.farnell.com/datasheets/2625802.pdf
"SSD1306 built-in controller"
And you need a connector to receiver the ribbon cable?
| improve this answer | |
  • \$\begingroup\$ Yes, the part you shared is matching wit mine! i would like to solder it on pcb. \$\endgroup\$ – Suhail Jr. Jun 11 '19 at 16:11
  • \$\begingroup\$ I believe you need a connector like this digikey.com/products/en/connectors-interconnects/… unless you are planning to remove the flex cable and mate the display to the board via some other means. \$\endgroup\$ – CrossRoads Jun 11 '19 at 19:45
