I'm designing an audio mixer and currently i'm working on a cue section. The whole point is that i have 2 or more channels and want to mix them in summing mixer. You can turn off the channels you don't want to hear - simple switch -> ground the channel you don't want to hear or connect it to the summing resistor.
When i turn off the channel the summing resistor is floating. Floating input of an op amp is usually not a good idea. Putting relays that ground the floating inputs when unused sounds like a lot of hassle. Any other ideas? Or maybe i can just leave this way? But i'm afraid that floating inputs will pick up a lot of noise.
    \$\begingroup\$ What is the signal source that becomes hard-grounded when the switch is in the shows position? what about turning the switch to ground to inputs of the summing amplifier? Depending on the (unknown) signal source I would consider to use separate coupling capacitors for the two inputs... \$\endgroup\$
    – aschipfl
    Jun 12, 2019 at 8:33
Yes, but you are not causing the "real" input to float...
Open circuiting the 47 kohm resistor that feeds the virtual earth summing input is not going to be a problem. The 47 kohm feedback resistor shown in your diagram will keep the op-amp biased at the right point.
Shorting to ground the signal that feeds the 47 kohm input resistor may not be such a good idea and you can probably get away with a switch that just disconnects the signal from the 47 kohm.
  • \$\begingroup\$ thank you very much! \$\endgroup\$
    – cubix
    Jun 12, 2019 at 8:41
  • \$\begingroup\$ Can you please explain why shorting the signal to ground is a bad idea in this case? I was thinking about connecting the relay in shunt mode, it will short the signal to ground. Is that really worse than leaving the open circuit? \$\endgroup\$
    – cubix
    Jun 19, 2019 at 17:28
  • \$\begingroup\$ If the input signal comes from a passive signal then it should be okay. If the signal comes from an amplifier or other active circuit then you might do it damage. \$\endgroup\$
    Jun 19, 2019 at 18:06
