I'm new to STM32. Recently I'm trying to understand the schematic of it. I came across the term "soldering bridge" default: open. Does it signifies that the two pins are opened (which means not connected) or it means two of the pins are shorted?
It's two adjacent pads intended to be bridged with solder to connect them depending on the board configuration. It's just like a jumper with header pins and a shunt but is cheaper and more permanent.
Open is not connected. Closed switch is connected. In electronics, we use the analogy of a switch, not a door or floodgate (which is opposite).
| improve this answer | |
It means they are normally not connected. You can place a blob of solder across it to connect if needed.
    \$\begingroup\$ But it's a good idea to look at the board and check. That's the sort of thing that is most likely to not match the documentation. \$\endgroup\$ – TimWescott Jun 12 '19 at 16:04
    \$\begingroup\$ Thank you for the help! I have performed connectivity on those bridges using my multi-meter and then verify that SB open signifies those bridges are not connected. \$\endgroup\$ – Chuang JY Jun 13 '19 at 1:25
I would suggest it means "Not connected". Thus pin 4 on the P-channel MOSFET Gate has to be taken low to pass along U5V from Source to Drain.
