I'm new to harmony framework, and am trying to find how i can count timer iterations, so i'm doing a simple test.
I configured the timer like this:
Now i want to know if this is the correct way:
    uint32_t teste;
    case APP_STATE_SERVICE_TASKS:
        while(1){
            teste = DRV_TMR0_CounterValueGet;
            printf("tmr val %d \r\n",teste);
            DRV_TMR0_CounterValueSet(0);
        break;
It happens that when i go see the print it's always the number 1660931680 doesn't make much sense to me, the timer is 16-bit so the maximum number should be somewhere near 65500.
What is wrong here?
You are probably getting the memory address of the DRV_TMR0_CounterValueGet function rather than the return value because you didn't call the function. You must call the function with () i.e.
teste = DRV_TMR0_CounterValueGet();
(not teste = DRV_TMR0_CounterValueGet;)
  • \$\begingroup\$ Hi @pm101 thanks it is always 0 now even after taking away DRV_TMR0_CounterValueSet(0);, do you know whats missing? i did DRV_TMR0_Start(); on APP_STATE_INIT \$\endgroup\$
    – Nmaster88
    Jun 13 '19 at 7:46
  • \$\begingroup\$ Ok i found what was wrong, i had timer period equal to one. I need to understand it now. \$\endgroup\$
    – Nmaster88
    Jun 13 '19 at 8:00
