I'm facing some problems in the initialization stage of the SD protocol on a custom board, specifically when sending the ACMD51
command and reading the Status Card register on the DAT0
line. I've noticed that, when the command fails, I see a duplicated CLK
signal on the DAT0
line.
The picture below shows the CMD
line(magenta), DAT0
line(yellow) and CLK(cyan). The last pulse before the B cursor is the end bit of the ACMD51
command. As can be seen, the DAT0
line replicates the CLK
while the command is transferring and even after the command is issued (just for one pulse).
I've looked in the specs and, from what I understood, DAT
lines should be HIGH when there's no data for transferring or LOW for signaling busy, but I don't get what could be the meaning of that duplicated CLK
, apparently sent by the card itself. Maybe I've missed some point on the specs. What could cause that oscillation on the DAT
line?
