Given the circuit I have to find the source voltage S and unknown resistance R3. It is stated that the power dissipated in R6 = 3 ohm is 0.75W. How should I attempt to solve the source voltage where there are two unknown variables?
Edit: Combining series resistors and trying mesh analysis:
14I1-2I2 = S ...(i)
-2I1+18I2-4I3 = 0 ...(ii)
-4I2+(7+R)I3=0 ...(iii)
P=(I^2)*R , So, I3=0.5A
    \$\begingroup\$ Show what you have attempted so far. \$\endgroup\$ – Solar Mike Jun 13 '19 at 10:09
  • \$\begingroup\$ Start by looking at the circuit, can it be simplified? I see that R1 and R8 are in series and can be combined.When the circuit is simplified write the network equations to find the solution. \$\endgroup\$ – Bimpelrekkie Jun 13 '19 at 10:14
  • \$\begingroup\$ R3 and R6 are in series. What do you know about current in series circuits? \$\endgroup\$ – JRE Jun 13 '19 at 10:28
  • \$\begingroup\$ Can you calculate the current through a resistor given the resistor value and the dissipated power? \$\endgroup\$ – JRE Jun 13 '19 at 10:29
    \$\begingroup\$ Have you heard of source transformation? \$\endgroup\$ – Andy aka Jun 13 '19 at 10:33
