-1
I need some help identifying a socket.
I have no idea what it might be. Websites offering help to classify didnt help.
Has anybody seen such a connection before and can give me some info? what kind of cable is needed for a connection?
The Image shows the back of the head from a Pepper Robot.
I can only guess about the dimension because it is hard to reach.
Width is around 8mm.
I assume it is used for data transfer and would like to find out if i can use it as energy source for an raspberry pi.
  • 6
    \$\begingroup\$ It's always helpful to know what kind of device that connector is on, and what you expect that connector to transport. Also, a scale would be most helpful. \$\endgroup\$ – Marcus Müller Jun 14 at 13:15
  • \$\begingroup\$ @MarcusMüller: Re scale: you can see a 50mm fan and an RJ45 (Ethernet) plug in the background. \$\endgroup\$ – Dave Tweed Jun 14 at 13:24
    \$\begingroup\$ What is this thing that the connector is on? \$\endgroup\$ – Tyler Jun 14 at 13:26
    \$\begingroup\$ Yeah, so, how many mm is that conenctor wide, what is the device that it's attached to, and what do you assume it transports. You've answered none of my questions :( \$\endgroup\$ – Marcus Müller Jun 14 at 13:29
Looks to me like a Micro-USB AB connector, like this Molex 47589-0001 or similar:
image from the datasheet
You can connect to it using any regular microUSB A or B connectors.
That said, it may not actually be used here to transport USB, but for debug/firmware flashing (could be used for low voltage serial, perhaps?) or something entirely different.
It would help to know what this device is and also what it connects to internally – say, the lack of a differential pair connecting to it would suggest that this is likely not used for USB, for example.
Alternatively, just probe and see.
Edit: If this is USB, the AB connectors are/were often used for OTG hosts. You may be able to attach an adaptor cable and draw some power from it, although running a raspi from it may be pushing it.
  • \$\begingroup\$ Thanks microUSB B actually fits. I tried it before but i was convinced it wasnt usb :-) \$\endgroup\$ – TVK Jun 14 at 14:47
