This question is pretty niche, but maybe someone investigated this topic before me and can give advice.
I want to source voice coils from HDDs (new or second hand ones). The more torque/force the better. What HDD properties do I need to look out for to have higher chance of finding stronger voice coils inside them?
closed as off-topic by Hearth, Chris Stratton, Dave Tweed Jun 15 at 11:07
This question appears to be off-topic. The users who voted to close gave this specific reason:
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ the old 1980's mainframe drives with 14 inch platters had huge magnets and voice coils that could accelerate to the velocity of around 300 MPH in the distance of 6 inches ... it is kind of hazy now, but it was something like that \$\endgroup\$ – jsotola Jun 14 at 22:13
  • \$\begingroup\$ That sounds great. What name/description do they go by? \$\endgroup\$ – user1282931 Jun 14 at 22:50
  • \$\begingroup\$ what are you trying to do? \$\endgroup\$ – jsotola Jun 14 at 23:05
  • \$\begingroup\$ i think that it was IBM 3340 or something similar \$\endgroup\$ – jsotola Jun 14 at 23:13
  • \$\begingroup\$ If you are going to want coils in any quantity it'll be cheaper to make them, or have them made. \$\endgroup\$ – TimWescott Jun 15 at 3:36
Look for high capacity drives,
More capacity means more platters, more platters means a heavier head assembly, and that's going to require a stronger voice-coil.
High capacity is a moving target, so you want to look for drives that were the largest model in their series when they were manufactured.
Disk drives have not used linear voice coils for at least the last 2-3 decades. The last ones I saw were on the bulky 14" and 8" drives used in workstations in the 1980s.
All modern drives (5.25" and down) move the heads on an arc using very flat but powerful rotary positioners with strong arc-shaped permanent magnets as stators.
  • \$\begingroup\$ That’s okay, it’s easy enough to translate the arc into the linear motion I need \$\endgroup\$ – user1282931 Jun 15 at 11:46
