I am trying to incorporate a TEC in a portable system. The heat from the interior of the system needs to be transfered to the exterior where it can be dissipated freely into the environment. Now, I have developed a thermal management design where heat is conducted outside via sheets of copper and will be ultimately deposited into a fabricated "water heatsink" where temperature differential is mitigated by water's high specific heat capacity and additional surface area. The water heatsink is consisted of coppersheets forming a thin container filled with water. The system needs to be compact and lightweight and this system seems to provide heat mitigation capabilities and an increased surface area.
Attached is the visual illustration of the design. Is this viable?
